Hello,
close to Xmas and now my BM4500 is no longer reacting. I need some signs of hope, as I am just having it for some time and actually did not listen to it, as speakers were arriving just day before yesterday... :o(((
I purchase it used and it had the 220V wires cut, same as the beogram 4500 which came along. The guy before simply put it together with a luster/ screw terminal and put it in the socket. It also worked for me, however as I did not want to plug it long term, I always pulled the plug out of the socket. It made some clicking noises, however it turned on afterwards with no problem - until today.
Beomaster is giving no sign of life.... I opened it and checked 3 fuses (marked with some color), but all of them appear to be still ok.
I would really appreciate, if someone can shed some light, on what this could be and particularly, if it can be brought to life for a reasonable amount of money...
Thanks,
Markus
