The glass panel on my receiver is loose.
Question#1: I have also lost FM to #'s 0,1,3 and 4. The rest work. I can get #1 and #3 to work if I press hard on the glass panel but of course that is unacceptable. All work through the Beolink1. Can the little tube switches be adjusted? Turned perhaps?
Question#2: I want to glue the glass panel back on. Could I just rub the (cork?) stripes with mineral spirits or some other solvent with a cotton swab to reactivate the glue? If that doesn't work maybe a very light coating of contact cement? If not that could you recommend an appropriate glue?
Maybe some knowledge on just how the tube switches work would be helpful. Being a novice, I'm truly thankful to all those who reply.
My sincere thanks,
Fonz
