1st March February 2012
Latest post 12-29-2010 2:42 PM by sodoi18. 13 replies.
12-21-2010 12:22 AM
sodoi18
- Joined on 02-06-2010
- USA
- Posts 194
Active beosystem 1 users - count
Some time ago I got a used beosystem 1 but never got to set it up. Before I go ahead and invest time in setting it up, just
Wanted to know, how many people are actually using it currently. And what do they think of it.
Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
sodoi18
- USA
- Posts 194
Re: Active beosystem 1 users - count
With not a single response Its fair now to assume that this unit from B&O is not being used by many at all. Now - I am not sure if I want to set this up my self.
sodoi18
- USA
- Posts 194
I am planning to have s45-2 as front playing through a beomaster 4500. Rear with two rl 60.2 connected via
A MCL2P
- Question:
1. Can I control volumes on rear and front separately, if so how
2. With beosystem 1 being the av processor how do I control it remotely with beomaster 4500 also in the same room.
3. Any suggestions on setup
I have 2 s45-2, two rl 60.2, one spare bl4000, and two spare bl2500 -
Thanks, all help is appreciated
beojeff
- Joined on 11-29-2007
- Posts 543
I currently use a BeoSystem 3 in the living room and a BeoSystem 1 in the den. The BeoSystem 1 has plenty of connections (once you add a Zektor expansion box) and plenty of PUC control. The big drawbacks you'll run into are the lack of HDMI and lack of 720p. The BeoSystem 1 only offers 480p and 1080i as HD. This limits you to the first gen Apple TV and not the second gen Apple TV. With the prices of second-hand BeoSound 1 being so low, it's certainly worth the bargain.
Beobuddy
- Joined on 04-18-2007
- Posts 1,582
Correct me if I'm wrong, but the system1 was only released in the States, and so not well known here in Europe. It has different connections (component in stead of scart).
So that could explane the number of reply's to your question.
Alex
- Joined on 04-16-2007
- New York, NY
- Posts 176
sodoi18:
A MCL2P
- Question:
You can't do that. The option programming to pull that off isn't available for the 4500 or the BeoSystem 1 (Video or Audio Option 4). They're going to need to be completely separate or linked together the way most audio/video products are linked together in the same room (4500 in what was option 0 ... System 1 in option 2).
I still use a System 1 in my living room with a 42" BeoVision 4. Still works like a dream!
Store Manager
Bang & Olufsen Broadway
927 Broadway
New York, NY 10010
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
Still using a BeoSystem 1 myself. I have a bit of a living history exhibit going on. Only real complaint could be lack of HDMI, but almost everything is available with component. PQ on old BV4-50 is pretty competitive with everything else in the house.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
sodoi18
- USA
- Posts 194
I got the system 1 set-up only to realize that i need the powerlink mk2 cable to trigger my beolink passive for the front bevox rl 60.2 to work.
Now I am in the wait mode for the powerlink mk2 cable to arrive. Strangely though according to B&O technical support ( honestly, very helpful people) the powerlink mk3 (triangle) cable - which is also fully mounted should be good enough. But in my experience it deos not work - any thoughts on this?
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
The error is that a Mk.3 Powerlink cable is not fully connected - it is just like Mk.1, but with better shielding that is often needed for interference suppression with ICE powered speakers.
I think joeyboygolf once said that he'll cover himself in ashes if he ever has to repeat this again in any thread, so I'll save him and reiterate his sound advice: for a Beolink Passive, you need a fully connected Mk.2 cable - nothing else will work! Should be fine once you get the cable
macjonny1
- Joined on 11-08-2009
- Posts 355
I'm using a beosystem 1 but only for audio switching. I hook all of the hdmi inputs to the TV. Sure i have an extra remote but that's not a concern to me.
Hildebrand
- Joined on 12-29-2007
- Phoenix, Arizona
- Posts 66
Still using a BeoSystem 1 for I believe 3+ years now, with my BeoVision 4-50! Run my DirecTV and PS3 through it at 1080i via a Zektor switch. Main room setup includes BeoLab 1, BeoLab 6000, BeoVox Cona & BeoSound 9000!
BeoVision 4-50 MkII, BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621
sodoi18
- USA
- Posts 194
What is the Zektor switch and which model do you use. I am not sure If I would need it. I am hoping to connect a 50" plasma for video via HDMI and process audio only through beosystem 1
I am planning to set up RL 60.2 through a beolink passive as front
A pair of S45-2 through a MCL2P as rear
Beolab 4000 as center
Wish to add a beovox cona - if i can find a used one
Sound Calibration - I noticed this in the beosystem 1 menu, please some one shed more light on this option and what does it do.
Thanks for details
Page 1 of 1 (14 items)
