Hi everyone,
Apologies for the daft question
I'm trying to get my BV8-32 to control a Humax Foxsat HD satellite receiver and I can't seem to get any control of this at all via the PUC options listed on the BV8 menu. I suspect that I need to get the STB table updated so that the Foxsat is specifically listed, but usually in the past I've had some measure of contorl by selecting a similar product from the same brand of STB in the PUC list. Not this time!
My BV8-32 is at STB table version 03.90a and it has a number of other Humax products listed (just not the Foxsat HD). I'm guessing that the only way forward is an STB table update?
Any ideas? Thanks,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
