Hiort:
Thats odd... You cant find it if you scroll down the list when you have activated "ADD"?
when I press LIST repeatedly I get: FORMAT STAND SPEAKER P-AND-P RECORD FORMAT...
after activating ADD? (through OK button?) I get AV? LIGHT? CNTROL?AV? ..(through repeatedly pressing LIST
am I missing something somewhere?
As regards the RC, it got delivered yesterday with the 10-40.
While we are at it and with lots of seemingly knowledgable folks around: the panel is somewhat slanted forward: top is 3mm further away from the wall than the bottom, (the wall itself in perpendicular) can this be adjusted?
Other than that: a magnificent piece!
