1st March February 2012
Latest post 12-09-2010 5:45 PM by Harry2008. 17 replies.
12-08-2010 11:00 AM
dueno
- Joined on 04-29-2007
- bordeaux
- Posts 147
look at
http://www.bang-olufsen.fr/specifications?productid=733
never explain never complain
talisman
- Joined on 05-06-2007
- Posts 52
Re: bv10-46: 2 or 3 HDMI?
BeoVision 10 - 46 MK II = 3 HDMI
BeoVision 10 - 46 MK I = 2 HDMI
BeoVision 4 - 50 HD - Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
talisman:
What?
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
LifeStyle
- Joined on 04-01-2009
- Posts 97
On www.bang-olufsen.com they changed the specs for the 10-46 from 2 to 3 HDMI, but is this really an official MK II version? Are there any other improvements at the MK II except of one more HDMI input?
Michael
- Joined on 05-20-2009
- Glen Waverley, Victoria, Australia
- Posts 245
In November, I looked at the 46" and it had 2 HDMI. I asked B&O Melbourne if it came with 3 and they said no. As it didn't have 3 HDMI, I chose a different brand of TV as I need a minimum of 3 HDMI.
I would hate if they have just updated.
When did they update it?
Regards
Michael.
bayerische
- Helsinki, Finland
- Posts 3,593
That's a fast update if it indeed was?
-Andreas
hagan
- Joined on 05-19-2007
- Posts 128
I got my new 10-40 27th October. It has 2 hdmi
br
/h
Raeuber
- Joined on 12-02-2007
- Posts 986
I was told the third HDMI is an internal HDMI for the HD module, so there are only two HDMI to connect other devices.
All BV10 (32, 40, 46) have two HDMI, although B&O homepage says three.
/Räuber
SteveB
- Joined on 04-16-2007
- Posts 25
I was told by my dealer that the BV10's currently being manufactured are updated in terms of connectivity and a 3rd HDMI is a result of this. He assured me that the 10-46 I have just ordered will be the later version with 3 HDMI sockets
Steve
bayerische
- Helsinki, Finland
- Posts 3,593
hagan:
br
/h
Well, B&O homepage says 3... That's what I'm hoping mine will have once I get it...
-Andreas
GuyHui
- Joined on 03-17-2007
- Posts 1,560
Well, that's a non sense that B&O just makes an update only few months after the launch of the BV10 46", in a customer point of view. I feel a little bit abused...as mine (2 HDMI version) was purchased on october 2010. I would have wait to get the 3 HDMI version "grgrgr"....*
Cheers,
--= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
bayerische
- Helsinki, Finland
- Posts 3,593
GuyHui :
Cheers,
I agree, I really hope mine has 3, because I remember reading on the B&O homepage when I ordered mine it had 3 hdmi inputs...
-Andreas
oli
- Joined on 05-10-2007
- Paris, FR
- Posts 62
These new specs are existing since August. Check the user manuals available, there is a pre august (2 HDMI) and a post august (3 HDMI) release. But AFAIK, all BV10 46 delivered until now have only 2 HDMI built in, and the panel description behind the TV is the one from the pre august manual.
bayerische
- Helsinki, Finland
- Posts 3,593
oli:
So b&o is misleading it's customers again... Just as they did with the early Beolab5's... Claiming they would work in syncro mode.
-Andreas
Harry2008
- Joined on 11-09-2008
- Netherlands
- Posts 252
oli:
My new BV10-46 was installed last Friday and has indeed 3 HDMI inputs available.
According to my dealer there are some internal improvements as well. One was about the cooling of the LCD screen. I am quite happy with it as the "clouding" is considerably less compared to my previous 10-40"
Page 1 of 1 (18 items)
