Latest post 12-09-2010 5:45 PM by Harry2008. 17 replies.
Page 1 of 1 (18 items)
  • 12-08-2010 11:00 AM
    • dueno
    • Top 500 Contributor
    • Joined on 04-29-2007
    • bordeaux
    • Posts 147
    bv10-46: 2 or 3 HDMI?
    look at
    http://www.bang-olufsen.fr/specifications?productid=733
    never explain never complain
  • 12-08-2010 1:05 PM In reply to
    • Beofan2
    • Top 200 Contributor
    • Joined on 07-31-2007
    • Fredericia, Denmark
    • Posts 313
    Re: bv10-46: 2 or 3 HDMI?
    BV 10 -46 has 3 hdmi.
    It´s not magic - it´s Bang & Olufsen
  • 12-08-2010 1:27 PM In reply to
    BeoVision 10 - 46 MK II   = 3 HDMI
    BeoVision 10 - 46 MK I    = 2 HDMI
    BeoVision 4 - 50 HD -  Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .
  • 12-08-2010 1:37 PM In reply to
    talisman:
    What? Geeked
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 12-08-2010 6:47 PM In reply to
    On www.bang-olufsen.com they changed the specs for the 10-46 from 2 to 3 HDMI, but is this really an official MK II version? Are there any other improvements at the MK II except of one more HDMI input?
  • 12-09-2010 4:10 AM In reply to
    Master Link sound delay
  • 12-09-2010 5:04 AM In reply to
    • Michael
    • Joined on 05-20-2009
    • Glen Waverley, Victoria, Australia
    • Posts 245
    • Gold Member
    In November, I looked at the 46" and it had 2 HDMI.  I asked B&O Melbourne if it came with 3 and they said no.  As it didn't have 3 HDMI, I chose a different brand of TV as I need a minimum of 3 HDMI.
    I would hate if they have just updated.
    When did they update it?
    Regards
    Michael.
  • 12-09-2010 5:10 AM In reply to
    That's a fast update if it indeed was?
    -Andreas
  • 12-09-2010 5:16 AM In reply to
    I got my new 10-40 27th October. It has 2 hdmi
    br
    /h
  • 12-09-2010 5:46 AM In reply to
    I was told the third HDMI is an internal HDMI for the HD module, so there are only two HDMI to connect other devices.
    All BV10 (32, 40, 46) have two HDMI, although B&O homepage says three.
    /Räuber
  • 12-09-2010 5:47 AM In reply to
    I was told by my dealer that the BV10's currently being manufactured are updated in terms of connectivity and a 3rd HDMI is a result of this. He assured me that the 10-46 I have just ordered will be the later version with 3 HDMI sockets
    Steve
  • 12-09-2010 5:48 AM In reply to
    hagan:
    br
    /h
    Well, B&O homepage says 3... That's what I'm hoping mine will have once I get it...
    -Andreas
  • 12-09-2010 6:19 AM In reply to
    Well, that's a non sense that B&O just makes an update only few months after the launch of the BV10 46", in a customer point of view. I feel a little bit abused...as mine (2 HDMI version)  was purchased on october 2010. I would have wait to get the 3 HDMI version "grgrgr"....*
    Cheers,
    --= "Everything gets done with Patience" =-- --= "Less is More" - Mies Van der Rohe"
    --= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
  • 12-09-2010 7:24 AM In reply to
    GuyHui :
    Cheers,
    I agree, I really hope mine has 3, because I remember reading on the B&O homepage when I ordered mine it had 3 hdmi inputs...
    -Andreas
  • 12-09-2010 7:31 AM In reply to
    • oli
    • Not Ranked
    • Joined on 05-10-2007
    • Paris, FR
    • Posts 62
    These new specs are existing since August. Check the user manuals available, there is a pre august (2 HDMI) and a post august (3 HDMI) release. But AFAIK, all BV10 46 delivered until now have only 2 HDMI built in, and the panel description behind the TV is the one from the pre august manual.
  • 12-09-2010 8:20 AM In reply to
    oli:
    So b&o is misleading it's customers again... Just as they did with the early Beolab5's... Claiming they would work in syncro mode.
    -Andreas
  • 12-09-2010 5:23 PM In reply to
    • Tim
    • Joined on 01-07-2008
    • Germany
    • Posts 114
    May I ask but what is a "syncro Mode" regardng the Beolab 5?
  • 12-09-2010 5:45 PM In reply to
    oli:
    My new BV10-46 was installed last Friday and has indeed 3 HDMI inputs available.
    According to my dealer there are some internal improvements as well. One was about the cooling of the LCD screen. I am quite happy with it as the "clouding"  is considerably less compared to my previous 10-40"
