Connect the VR 1 to the V.TAPE socket of the TV-set using a fully specified
21/21-pin A/V cable (SCART RGB cable).
Assuming no other external video source (e.g. SAT/Cable Set-Top-Box,...) is connected
fill in the menu as follows:
V.Tape AV Decoder
V.Tape None None
If other sources have to be connected use either the "AV" or the "Decoder" socket.
The menu offers you commands like "V.Tape2" ; "V.Aux" ; ... for that sources.
You'll have to "ADD" these commands to your Beo4 "LIST" to access these inputs
If Beocord VX 7000 type 458x is equipped with software (S/W) 3.0 or higher,
(order No. 8342818) the coloured keys on the Beo4 remote control can be used
for the CUE and SLOW functions. VX 7000 must have an SPR kit to function with
software higher than 2.0
