Latest post 12-07-2010 5:40 AM by tim22. 6 replies.
Page 1 of 1 (7 items)
  • 12-05-2010 2:17 PM
    • tim22
    • Not Ranked
    • Joined on 12-05-2010
    • Posts 4
    connecting VX7000 to Beovision Avant 28" DVD
    Have changed my MX4000 TV for a Avant 28" with built in DVD. How do I connect my VX7000 VHS player (that worked fine with the MX4000) to my Avant 28" TV. The only manuals I can find are for the Avant 28" VHS which has different connections. Have tried connecting to the Avant AV scart input and pressing VTAPE on BEO4 remote but get a blank screen and no sound. Will appreciate any help
    Tim22
  • 12-05-2010 2:28 PM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Re: connecting VX7000 to Beovision Avant 28" DVD
    I have never had an Avant but this might help. Somewhere in the Avant's menus there is a part called Connections where you can assign different inputs to different functions (or buttons in your Beo4). In your case you should set the AV input to V.TAPE.
    Bang & Olufsen - The art of controlling sound, picture and light
  • 12-05-2010 2:50 PM In reply to
    • tim22
    • Not Ranked
    • Posts 4
    Hi lausvi
    Thanks for response, do not have V TAPE on the connections menu, only V TAPE 2, have tried that but without success
    Best
    Tim
  • 12-05-2010 3:59 PM In reply to
    You should connect it to the AV-connection named VTAPE (Scart-connector on the most left side seen from the rear of the Avant). In the menu you should also name this connection VTAPE. I would not use the AV-socket for V-tape since there is no tuner-dump on this connection.
  • 12-05-2010 4:23 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Connect the VR 1 to the V.TAPE socket of the TV-set using a fully specified
    21/21-pin A/V cable (SCART RGB cable).
    Assuming no other external video source (e.g. SAT/Cable Set-Top-Box,...) is connected
    fill in the menu as follows:
     V.Tape         AV             Decoder
     V.Tape         None           None
    If other sources have to be connected use either the "AV" or the "Decoder" socket.
    The menu offers you commands like "V.Tape2" ; "V.Aux" ; ... for that sources.
    You'll have to "ADD" these commands to your Beo4 "LIST" to access these inputs
    If Beocord VX 7000 type 458x is equipped with software (S/W) 3.0 or higher,
    (order No. 8342818) the coloured keys on the Beo4 remote control can be used
    for the CUE and SLOW functions. VX 7000 must have an SPR kit to function with
    software higher than 2.0
  • 12-07-2010 5:35 AM In reply to
    • tim22
    • Not Ranked
    • Posts 4
    Thanks Blackrix, problem solved
  • 12-07-2010 5:40 AM In reply to
    • tim22
    • Not Ranked
    • Posts 4
    Thanks Vienna,
    problem solved, VHS working fine and thanks for extra info.
    Will have to get a digital box when the analogue signal is turned off, can I just plug the feed from the box into the VHS input?
    Tim22
