The 7-32 & 7-40 Not sure about the 7-55 have a service
stand/tool,which is a long square piece of metal maybe 1" wide by 1" high by 10" long that
have a long 5 inch spike sticking up in the middle of each one.
When the Beovisions are taken off there normal stands for servicing/repair,there is two holes under the tv,which two of these service tools push in too,so you can stand the tv up on a bench to work on.If you are looking at the front of the set,each stand would maybe 10" along the underside of the set one on the left and one on the right!
Hope this gives you an idea Elephant!
As stands they do look rubbish..
Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
