1st March February 2012
Latest post 10-26-2008 2:21 AM by Bieele. 75 replies.
Corvin
- Joined on 04-16-2007
- Australia
- Posts 124
Re: The Beosystem 3 Owners Thread
Frog, I was in the same situation, i can not remember how i got the discreet on and off codes but remember looking at these codes from other products in the same brand. Maybe try this looking at the code string. Or perhaps Michael from Lintronic may be able to assist. Good Luck
stefan
- 200 miles from Struer
- Posts 1,733
Try the discrete on/off codes of the Samsung projector. You find them in the Lintronic-database. They work fine at my son`s Samsung 17M24 LCD TV.
Stefan
frog
- Joined on 04-19-2007
- Posts 191
Thanks - I'll give them a whirl when I'm next back at the house.
brendon
- Joined on 04-18-2007
- Posts 54
HI Just got my BeoSystem 3 setup. I have connect my BS3000 and Mac with the Beoport. Is there a way I can see my Mac on screen while the music is playing? In other words my BS3000 would be play and the BS3 would have the screen up. I would like to see what I'm selecting on my Mac while listening to the music. Thanks
Max
- Devon
- Posts 64
Hi Brendon, Congratulations on your BeoSystem purchase and welcome to the thread! I'm not sure on the Beoport setup with the BS3000 and Mac but try adding the AV option to the list button and then when you have the screen displayed hit the AV option from the list and then select the audio source. I have my BS3200 setup in this way which means I can see the TV picture and listen the RADIO/CD/A.MEM. Max.
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Everyone in this thread has a low amount of posts under their belt, does this mean that the Beosystem 3 is that good, that it is more captivating than Beoworld?!
kawo
- Posts 516
That's a good one!! The BS3 is a great concept and now playing with it the last couple of month I would say there is still some room for improvement :-) Hopefully the next SW upgrade will fix some of the problems with disturb my relationship to the BS3 every day, but to early to talk about a potential divorce..... My dealer just upgraded the PUC list for me so I know have my Toshiba HD-DVD controlled by the Beo4. Works without any problem except power on works not always, power off never. It is interesting how important this one remote concept is, even it is nothing special, but now I love my BS3 more than before :-) I also have the Apple Remote PUC uploaded, but did not receive my AppleTV to test. An other interesting feature is if you feed a 4:3 DVD (Eagels Hell Freeze over) via HDMI in 1080p to the BS3 and can not rescale it to 16:9. So I get the anoying black bars on the left and right. I will do some further testing who is the source of the problem, my lovely B&O stuff or this japanese DVD player :-) Karsten
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
frank2u
- Posts 43
Hi brendon, it is not possible to see the screen of the Computer where the Beoport is connected to. It is only possible to see the screen if you use the Beomedia. Frank
mbee
- Paris, France
- Posts 1,133
kawo: An other interesting feature is if you feed a 4:3 DVD (Eagels Hell Freeze over) via HDMI in 1080p to the BS3 and can not rescale it to 16:9. So I get the anoying black bars on the left and right. I will do some further testing who is the source of the problem, my lovely B&O stuff or this japanese DVD player :-)
No system on the market (B&O or not) will allow you to change the format if your input is 1080p HDMI : it considers that the format is already the right one (and that's true, your DVD player is sending a 16:9 signal in 1920x1080p, with the black bars), there is no 1080p signal in 4:3... So the best way is to send the DVD signal "as is" : not upscaled : the BS3 will do the upscaling, and as it is one of the best upscalers on the market, you will get the best of your DVDs... If you want the DVD player to upscale, then you have to change the format with the DVD player, not with the BS3 (but the first solution is the best...)
kawo
- Posts 516
agree, the only downside that you want the HD-DVD player to send the HD videos in 1080p to the projector, unfortunately the Tosh does not allow to configure two different settings for e.g. DVD and HD-DVD. So you have to go to the menu and change in manually....or get a second DVD player :-) Karsten
cmitchel
- Joined on 08-25-2007
- Posts 3
Re: The Beosystem 3 Owners Thread - reset query
Hi Max or anyone, I need to reset my Beo System 3 to factory settings, you mention a beo4 reset procedure, could you tell me how to do it or point me in the right direction? thanks, Chris
frog
- Posts 191
It is in the system menu; MENU, Choose OPTIONS, 0,0,GO them Monitor Information then the last option is reset.
cmitchel
- Posts 3
frog, thanks but the BV4 plasma is not working and i suspect it may be due to a config error, so I need to reset without the on-screen menu. I was hoping there was a hard-reset button on the Beosystem 3 or a Beo4 procedure? cheers
Max
- Devon
- Posts 64
Hi, Sorry for the delay, I've been tied up with some bank holiday weekend DIY. As you are a gold member, it maybe worthwhile downloading the service manual, if you haven't already, at http://www.beoworld.org/manuals_view.asp?pid=863, and the procedure is listed under Adjustment and Repair Tips -> Repair tips -> Reset command. Max.
cmitchel
- Posts 3
Many thanks Max. Cheers, Chris
brendon
- Posts 54
Hi Frank Here is a way to do see my Mac on screen and and see my music\Itunes at the same time. First set: Beo System 3 to Video (IE the Mac singal) Second: must use the "A.Netmusic" on the Beo4
donoghueb
- Joined on 12-16-2007
- Posts 3
Can anyone in this thread offer some advice? I have a Beo3 connected to Beo4 plasma. My STB comes through V-MEM. When I turn it on the 16x9 signal from the STB defaults to Format 1 (4x3) instead of the correct Format 3. Is there a way to correct this default? (The STB is correctly set t 16x9) Bob.
frank2u
- Posts 43
Hi, my dealer told me that there is a new version 4.0 for the BeoSystem3. Anybody knows what are the new features? My dealer doesn't. Frank
Gerd
- Joined on 04-20-2007
- Germany
- Posts 523
New SW 4.0 for Beosytem3 was released on 14-12-2007 with service tool v1.85f !
355f
- Posts 655
Gerd: New SW 4.0 for Beosytem3 was released on 14-12-2007 with service tool v1.85f !
What does this offer over 3.1 please
Gerd
- Germany
- Posts 523
355f: What does this offer over 3.1 please
No info so far - sorry!
-multimedia Robert-
- Holland
- Posts 401
frank2u: Hi, my dealer told me that there is a new version 4.0 for the BeoSystem3. Anybody knows what are the new features? My dealer doesn't. Frank
Rumour go’s Beosystem 3 new feature will be the possibility to set up the place the viewer actually is in the room. So to speak “where we Beoworlders are enjoying our movies in our own cinema!”. To adjust the (Dolby) speaker setup. Not sure if it is software only….(who knows?) A bit like my picture shows, in the premium Audi’s with advanced B&O sound system. Picture shows an Audi A8 at a car show. One can setup All, Driver, Front, Rear etc. (DSP Bang & Olufsen setup) Regards, Robert
Klas
- Singapore
- Posts 96
Anybody that has a quick solution/not to expensive - to connect the BS3 to a TV that only has VGA and Component input?? I've ordered a DVI-D board to my plasma (have a commercial version with interchangeable boards) - but it's been delayed for 4wks and i can't use my new BS3 except on my 24" computer LCD :( :(
Grant me the serenity to accept the B&O I can't afford
