1st March February 2012
Latest post 10-26-2008 2:21 AM by Bieele. 75 replies.
apearce
- Joined on 10-26-2007
- Posts 80
Re: The Beosystem 3 Owners Thread
It's certainly been a long time since anyone has used this thread, however my Beosystem 3 was installed last night by my local dealer and i have to say it's INCREDIBLE!!! Everything worked first go with my Sony LCD and the picture quality on the screen is, in my opinion, better than before! I'm still in the process of sourcing a centre speaker however even with stealing my rear BL3 to use as centre, it sounds incredible. I'm also controlling everything through my Beo4, which has shed at least 3 remotes. So far, no issues!!
Beosystem 3, Beosound 4, Beolab 9, Beolab 3, Beolab 8000
Max
- Joined on 04-19-2007
- Devon
- Posts 64
Congratulations and welcome to the club! Let us know how you get on and keep us posted of your centre speaker choice. Max.
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
apearce: It's certainly been a long time since anyone has used this thread, however my Beosystem 3 was installed last night by my local dealer and i have to say it's INCREDIBLE!!! Everything worked first go with my Sony LCD and the picture quality on the screen is, in my opinion, better than before! I'm still in the process of sourcing a centre speaker however even with stealing my rear BL3 to use as centre, it sounds incredible. I'm also controlling everything through my Beo4, which has shed at least 3 remotes. So far, no issues!!
What model Sony are you using? Does the Beo 4 turn it on and off just as if it were a B and O panel?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
apearce
- Posts 80
I have the KDL-46X2000, unfortunately there is no RS232 port on it so i'm stuck with 2 remote controls....one that simply turns the TV on and Off and the Beo4 that does EVERYTHING else......it's bearable....for now. Actually the one thing i need to look into is the converter that takes in IR and converts to Bluetooth for my PS3. What does everyone use for this? I've seen articles on the IR2BT, does anyone have any experience with this, or can offer advise on others?
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
The BS3 can have a puc update to conrtol a PS3 as it output the controls for the PS3 convertor remote what takes in the IR signals and plus into the ps3 via USB as it was origianlly for the PS2. As for turnign the tv off why not buy a lintronic convertor so when you press the source of anything visual it can output the on command for your tv and when you press off it outputs the off comand.
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
apearce
- Posts 80
I have the PS3 pucs installed on the BS3, i just need to get a reliable converter, so still on the hunt. What converter are you referring too, i've not had any experience with the Lintronic range so if you could send a link or part code that would be great.
Seanie_230
- Posts 962
Hi there the puc is actually for a device for the PS2 as this had a USB receiver that recieved codes from a IR remote and sends them into the PS2 via USB B&o puc code is for that convertor someone on here will know or have a search as i explored this a short while ago. As for the convertor im not 100% up to date but you can get a http://www.lintronic.dk/TT455-RT-238.htm and program it to receive commands and send out other commands as i say many other users ono here have so much more info as others use it.
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
apearce: I have the PS3 pucs installed on the BS3, i just need to get a reliable converter, so still on the hunt. What converter are you referring too, i've not had any experience with the Lintronic range so if you could send a link or part code that would be great.
I am using a Nyko remote to control my PS3 via BS3 http://www.nyko.com/nyko/products/?i=113 /weebyx
Seanie_230
- Posts 962
thanks Weebyx i knew someone woudl help out there
Weebyx
- Denmark
- Posts 321
seanklemis: thanks Weebyx i knew someone woudl help out there
I got the tip from my dealer, apparantly this is the remote that the PS3 PUC controller codes has been made for, i borrowed one from my dealer, and it works like a charm. One thing though, it is not possible to turn the PS3 on/off with this remote, since the PS3 shuts off the power to the USB port when turned off. However i am just using my orig. PS3 remote to turn on/off with, and then Beo5 to the rest, By the way, it is not easy to play GTA5 Prologue with Beo5 :) /Weebyx
apearce
- Posts 80
Thanks Weebyx, I popped into my dealer yesterday and he showed me that exact remote, so i've just ordered one online (£8.95). So is it just Power On/Off that can't be controlled?? Is there a solution for this?
Weebyx
- Denmark
- Posts 321
apearce: Thanks Weebyx, I popped into my dealer yesterday and he showed me that exact remote, so i've just ordered one online (£8.95). So is it just Power On/Off that can't be controlled?? Is there a solution for this?
I believe someone has been experimenting with a strip of electric leading material which is placed over the physical on/off button, and then controlled via some ir device. I have just accepted that i need a controller or PS3 remote to turn on/off with. It is not worth the hasle i think. /Weebyx
subversive
- Joined on 06-01-2007
- Ashburn, VA
- Posts 19
Beosystem 3 can turn sony panel on/off. I've my sony panel listed in the BS3 puc list. I am using IR flasher that goes in the BS3 IR1+2 to the sony screen and i am able to turn the tv on/off using beo 4.
Weebyx
- Denmark
- Posts 321
subversive: Beosystem 3 can turn sony panel on/off. I've my sony panel listed in the BS3 puc list. I am using IR flasher that goes in the BS3 IR1+2 to the sony screen and i am able to turn the tv on/off using beo 4.
But that does'nt work with the Playstation 3. It is not possible to turn the PS3 on via IR receivers since the PS3 shuts off the power to the USB ports when off. You can turn it off via the PS3 menu, but you cannot turn it on again. The PS3 uses originally Bluetooth as remote devices, so for it to be able to handle the IR codes from BS3, then you need a IR dobgle that goes into the PS3 USB port. /Weebyx
apearce
- Posts 80
Thanks for that subversive, is the IR on the Sony, the far right light on the glass section at the bottom?? If not, can you explain where it goes.
subversive
- Ashburn, VA
- Posts 19
It is on the far right side on the glass section of the sony screen and you can place it behind that glass instead of front. You would also need an IR Y adapter that will go on the IR 1+2 on BS3. IR Y adapter has 1 input silver and the other Gold. If your B&O dealer doesn't know send me a PM and I will get you the part number. The IR cable will go in either silver or gold input. I don't know exactly which one because i would have to look at my setup.
subversive
- Ashburn, VA
- Posts 19
USB port. /Weebyx I agree with you about the PS3 but I was talking about turning on/off sony panel not PS3. I am controlling my PS3 using a Nyko USB dongle and it works great except turning on/off. I really don't care about the on/off feature because I've to get up anyway to place the disk in the PS3.
rednik
- Joined on 06-29-2007
- Posts 150
Have any of you actualy found a Uk seler for the Nyko dongle? Maybe my google skils are leting me down but I can't find any in the UK. Thanks
subversive
- Ashburn, VA
- Posts 19
Sorry! I am in USA and there are plenty available here in store and online.
Weebyx
- Denmark
- Posts 321
subversive: subversive: Beosystem 3 can turn sony panel on/off. I've my sony panel listed in the BS3 puc list. I am using IR flasher that goes in the BS3 IR1+2 to the sony screen and i am able to turn the tv on/off using beo 4.
But that does'nt work with the Playstation 3. It is not possible to turn the PS3 on via IR receivers since the PS3 shuts off the power to the USB ports when off. You can turn it off via the PS3 menu, but you cannot turn it on again. The PS3 uses originally Bluetooth as remote devices, so for it to be able to handle the IR codes from BS3, then you need a IR dobgle that goes into the PS3 USB port. /Weebyx I agree with you about the PS3 but I was talking about turning on/off sony panel not PS3. I am controlling my PS3 using a Nyko USB dongle and it works great except turning on/off. I really don't care about the on/off feature because I've to get up anyway to place the disk in the PS3.
Ah, ok, så you were commenting on another message ? It is a bit confusing when not using the "quote" option instead of the reply :) /Weebyx
apearce
- Posts 80
I bought from ebay, should arrive early this week.
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
Being such a complex product, would you consider this product worthy of its own forum like the Beo5 - or do you think this one thread will suffice? Please bear in mind a forum must be used regularly.. Lee
apearce
- Posts 80
I think that questions about BS3 come up, but maybe not enough to warrant a dedicated thread, as you said, it would need to be used regularly.
kawo
- Joined on 04-17-2007
- Posts 516
Lee, I don't think we need an extra forum! Hopefully this thread will be used more and more instead starting new ones with simular questions. May be the moderators should close other threads and force the members to post here to avoid tons of new useless ones. Karsten
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
Peter Jacobs
- Joined on 01-31-2008
- Melbourne Australia
- Posts 65
Actually perhaps we do need a mini BS3 forum. After all the BS3 is gaining in popularity including its use with non B&O peripherals. AND (never start a sentence with a conjunction) my new BS 3 arrives tomorrow. I am 50 and my wife says I have been impossible to live with for the past week. Tomorrow I shall be receiving (drum roll) a Beosystem 3, Beovision 4 50", Beoliving Samsung Projector with auto Projector Lift, Stewart 100" in ceiling stealthscreen, Beolab 10 centre speaker and a PS3. I already have a pair of Lab 5s, Lab 3s, BS9000 . Will take pictures and post as the installation progresses. I expect I will be posting and using this thread quite a bit over the next few days / weeks. ON an even more positive note I just want to thank this forum. Over the years I have derived both inspiration and motivation for more and more B&O (the madness must stop) and must thank Peter, Lee, Keith and others for their energy and committment in keeping this forum on the straight and narrow and on balance an unbiased one (warts and all). Peter
