1st March February 2012
Latest post 03-19-2011 10:28 PM by Hildebrand. 9 replies.
11-25-2010 3:12 AM
carlito
- Joined on 04-19-2007
- Switzerland
- Posts 97
Software Update Beolab 3500 - Which Part number?
One of my Beolab 3500 is showing A-TAPE2 instead of N-MUSIC
Which part number is the PCB Board? I could not find anythink with searching the forum.
Thank's for quick help
Carlo
LC
- Joined on 11-23-2010
- London
- Posts 24
Re: Software Update Beolab 3500 - Which Part number?
version 2.1 changed the display names to n.music/n.radio
you can do this by replacing microcomputer PCB36, part no.: 8006009
or now there is sw 3.3 which allows it to support the a.aux command and ml gateway compatible!
you have to Exchange the uP module PCB36, part no: 8002944.
i pressume it will be better to go with the later one i believe its compatible as long as your beolab 3500 has an ML socket.
Louis
stringbag
- Joined on 12-26-2010
- Bath, UK
- Posts 24
Can someone (Keith saunders perhaps) check this part number please. If it is the case, then his guide should be updated.
Btw cost for the 8006009 is now apx £43 inc vat.
Beocentre 6-26, DVD1, beolab 3500, beocom4, beotalk 1100.
stringbag
- Bath, UK
- Posts 24
Hi Keith
Yes, that is the guide, and very useful it is too - thank you.
My question was in reference to the previous post - has the sw version changed to 3.3 with this latest pcb, and is it applicable for all versions of the beolab 3500, or just the later ones?
Louis:
Louis
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
The latest version of Beolab 3500 software is 3.33
When you upgrade a Beolab 3500 Mark 1 to version 2.1 as defined in the FAQ it changes the display as follows:-
A.TAPE -> A.MEM A.TAPE2 -> N.MUSIC V.TAPE -> V.MEM V.TAPE2 -> DVD2 CDV -> DVD PHONO -> N.RADIO SAT -> DTV
The part number for updating the software by replacing the micro processor PCB36 to 2.1 is 8006009
You could update your Beolab 3500 to version 3.33 by using part number 8002944 but would provide no benefit unless your unit was a Mark II version and you plan to use wireless.
Updates after 2.1 to 3.33 provide Master Link Gateway compatible and A.AUX command is now possible. Version 3.1 provided wireless compatibility.
stringbag
- Bath, UK
- Posts 24
Thank you for your reply and explanation Keith.
Keith Saunders
- Posts 3,810
The short answer is NO
The Beolab 5000 are powerlink speakers and the Beolab 3500 is a link room speaker meaning it uses a Masterlink connection.
Hildebrand
- Joined on 12-29-2007
- Phoenix, Arizona
- Posts 66
Greetings all, so just to clarify. Notice Louis mentioned you can update your earlier BL3500 as long as it has ML.
Then Keith mentioned that you can update your BL3500 to SW3.33 but would provide no bebfit unliess your unit was a Mk2 version and you plan to use wireless. Did you say an Mk2 version because of the ML socket or is there more to it then that?
Seeing that I have a older BL3500 yet it has both MCL and ML sockets would I get the full benefit of going to SW3.1 or 3.33?
Regards,
Hiller
BeoVision 4-50 MkII, BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621
Page 1 of 1 (10 items)
