Latest post 11-23-2010 2:55 PM by Ziggy1972. 5 replies.
Page 1 of 1 (6 items)
  • 11-22-2010 5:23 PM
    Arm problem on my BEOGRAM 4004
    I recetly aquired a B & G system with a Beogram 4004. When I press start, the arm moves into position, but will not drop. I can push it down with my finger, but it pops back up. I don't have a user's manual, so it may be something silly that I'm doing. Any suggestions please?
    Pat.
    Filed under:
  • 11-22-2010 7:18 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: Arm problem on my BEOGRAM 4004
    Hi Ziggy, if you hear a loud click** when the arm is expected to lower, then it is just dried lube on the mechanism. Fairly straight forward for the mechanically minded requiring partial strip and re-applying a good quality lube such as singer oil - there are lots of posts on this common issue to help you, although people are always willing to offer advice here!
    I would highly recommend you download the service manual and follow the set up procedures to get the best out of the turntable. New belts and other kits / parts are available from member Dillen.
    ***Sorry I should say if there is no click it could still be due to a bad case of dried lube....
    Olly.
    Filed under:
  • 11-22-2010 7:58 PM In reply to
    Thanks, I'll pick up some lube during the week and give it a try. It's been in my in-law's attic for about 10 years, so that could be it.
  • 11-23-2010 6:11 AM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    pick up some singer oil on ebay. Don't use anything like wd40, and I wouldn't advise 3in1 either. It is best to remove the arms but you will need circlip pliars for this, and a lot of care.
    Olly.
  • 11-23-2010 2:26 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    If it is simply dried lube (which is highly likely) then you really need to disassemble the mechansim & remove the old stuff before relubing & assembling. If you don't then the fault is likely to return in the near future.
    I've attached a photo of the points which need attention. Silicon grease is your best option.
  • 11-23-2010 2:55 PM In reply to
    Thanks, I appreciate all the help.
