Latest post 11-23-2010 12:28 PM by Alex. 9 replies.
Page 1 of 1 (10 items)
  • 11-21-2010 3:05 PM
    • Chris
    • Top 200 Contributor
    • Joined on 03-19-2010
    • Corbridge, UK
    • Posts 353
    • Gold Member
    Beovision 7 Mk2-3-4 picture quality
    Hi there
    I'm about to move into a new house shortly, so being a bloke the first bit of furniture that is coming off our meager furniture fund is of course, the TV :-)))
    Question. If you had about £3,000 and you wanted a second hand B&O tv with HD what would you have? I have seen a few 8's with its 40inc full HD 100hz screen and yes that is appealing. But i have also seen a few 32 inch 7's for about the right figure. Marketed as HD are they full HD. This would be by far what i would be looking for. I have seen a 40 inch 7 in a mk 2 format for about £4,000. This would always be my tv of choice so if i sleep on the floor and use the tv box as a sofa i would stretch to this. In its mk2 format wuld the 7 be a full HD tv?
    Anyway over to you and your greater knowledge.
    A Beovision 10-40 in black and red fret on order, Beo4, Beo6, many A8's, a pair of white and yellow Form 2's, Beocom 4, 28 inch Avant RF DVD, Apple TV and a wife that loves this stuff as much as i do!
  • 11-21-2010 3:48 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Beovision 7 Mk2-3-4 picture quality
    Frankly spoken 7-32/40 are really excellent even in non HD versions (actually never understood the big difference when in DVB-T) and already use one 7-32 in my bedroom.
    BUT as a value for money, I would go probably for the newer 8-40. I'm sure with this money you will also get DVB-T and ML (for future use)!!!
    Best regards
    Spiros
  • 11-22-2010 12:37 AM In reply to
    Hi, in answer to your question Mk1 and Mk2 7-40 are not full HD i.e. 1080P.
    The 8-40 does not have ML as standard.
    If considering purchasing a TV at that price level then take advice from any one of the three principal pre-owned resellers (in the world I guess!)
    £4000 is top money, you should also consider a MK1 HD.  Depending on whether you want a motorised floor stand or a 7-1/7-2 speaker you can purchase for around the £3250 mark from morethanAV, which I represent (7-40 MK1 HD, 7-1, motor floor stand).
    However see what all of the pre-owned Companies can offer and what advice they can give you, if you go for a full HD 7-40 MK3 onwards the prices jump!
  • 11-22-2010 12:54 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Well you are probably right and of course this is why I mentioned my self Value for Money since the 8-40 is cheaper, has intergraded speakers and the ML module should cost no more than 100 euros (new) but usually is already installed in most of them. First choice would be 7-32/40 but still a big difference in the value!
    Best regards
    Spiros
  • 11-22-2010 3:23 AM In reply to
    What about the new Beovision 10 - 32 ?
  • 11-22-2010 4:50 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    I think it would be a price issue there!!!! Unless there is a special price!!!
    Best regards
    Spiros
  • 11-22-2010 5:06 AM In reply to
    chris:
    I've heard people say that the Mk1/2 720p versions of the 7-40 handle SD input better than the newer 1080 panels. Can anyone confirm this? I would tend to go for the new BV8-40 but the lack of a motorised table or floor stand would be a problem if you are used to that facility. You should be aware that the newer TV's offer much better connectivity for digital sources than B&O's first generation LCD's.
    David
  • 11-23-2010 9:25 AM In reply to
    • quader
    • Top 500 Contributor
    • Joined on 08-03-2007
    • West Yorkshire, UK
    • Posts 89
    • Gold Member
    if you can stretch  it to 40 mk3 then you will have bs3 functionality
  • 11-23-2010 10:28 AM In reply to
    • Chris
    • Corbridge, UK
    • Posts 353
    • Gold Member
    Thanks everyone.
    As said i would prefer a full HD tv so i guess the 8 is really the only choice. I am struggling to convince the wife who doesn't think it looks like a B&O tv should, especially at £3,000 ie special. Why shouldn't i buy the the Samsung at £1,000?. I have a good sound system already! I am normally loyal to a brand that through its ancestory has proven itself over the years but who knows this time!
  • 11-23-2010 12:28 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    From a picture quality point of view, the 7-40, 7-55, 8-40, 10-32, 10-40 and 10-46 are all significantly ahead of the 7-32, especially when comparing HD images (which is where the 7-32 still really, REALLY struggles IMO).
    I'd personally choose a 10-32 over a 7-32 any day for the picture, even taking the differences in features into account...
     Weekly top artists:
