hilton:
how can i display 1080i on beovision 6 26?
and how do i set my pc up on it when there is no VGA.
BV6-26 MK I Type 925x and MK II Type 9270-9275 = Panel (native) resolution = 1280 x 768 pixels
BV6-26 MK IV Type 929x = Panel (native) resolution = 1366 x 768 , TV already beeing "HD-Ready"
You'll need a "HD-Ready Kit and SW Updates" for BV 6-26 MK I or MK II
to display HD signals coming from video sources like DVDs, STBs,... connected either by:
YPbPr - 1080@60i 1080i (1125i) (source resolution 1920 x 1080)
HDMI - 1080@60i 1080i (source resolution 1920 x 1080)
Mounting a "HD-Ready Kit and SW Update" will need a qualified B&O technician ...
DVI-I Input (using BV 6-26 as a computer-monitor)
no "HD-Ready Kit" is required.
Using the appropriate type of cable (DVI<>DVI OR DVI<>VGA),
connect one end to the DVI !!OR!! VGA output socket on your computer,
and the other end to the DVI socket on the television.
To hear sound from the computer in the television speakers,
use the appropriate cable and connect the sound output on
the computer to the L – R sockets on the television.
DVI connection for receiving digital OR analogue
graphics from an external PC.
Supports the following resolutions:
60 Hz;
640 × 480,
800 × 600,
848 × 480,
1024 × 576,
1024 × 768,
1280 × 720.
IMPORTANT! If you wish to connect a computer to the television
and use the television as a monitor, make sure that the television,
the computer, and all equipment connected to the computer are all
disconnected from the mains before you connect the computer and the
television to each other.
In addition, the computer must be connected to a grounded wall outlet
as specified in the computer’s setting-up instructions!
