        1st March February 2012
	    Latest post 11-12-2010 5:18 PM by  kimberley. 7 replies.
								        11-10-2010 3:01 AM
									        Søren Hammer
								                - Joined on 01-07-2008
								                - Esbjerg/Denmark
								                - Posts 554
										    What kind of cassette tape do you use?
										    Hello fellow Beoworlders, I am wondering which tape, you normally use with your beocords
I am using the new series of TDK SA-90's, and my parents' old Maxell UDXLII's, and soon some TDK MA Metal tapes
-Søren
									    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
									        tournedos
								                - Joined on 12-08-2007
								                - Finland
								                - Posts 5,808
										    Re: What kind of cassette tape do you use?
										    The ones that I happen to have. I think I last bought cassettes in 1990 or so
...and they were mostly TDK SA-X type II it seems, still have a couple in wrappers. Others that have held up well have been Maxell UD-II, Sony UCX-S and from the cheaper ones, Sony HF-ES. I have plenty of Dolby C recordings done on my JVC KD-D50 from 1982 on, and most of them still play great on my B&O decks - and of course the JVC, I still have it.
									        Søren Hammer
								                - Esbjerg/Denmark
								                - Posts 554
										    Hehe, those SA-X are nice tapes, just ordered 40 very cheap assorted chrome tapes, mostly TDK and Maxell
									        Eugene
								                - Joined on 12-17-2008
								                - Posts 589
										    Maxell UD XLII's were always my tape of choice. I still have a few recordings from the 80's that play well even today.
									        Søren Hammer
								                - Esbjerg/Denmark
								                - Posts 554
										    The UDXLII's are great tapes, I listen to some tapes recorded in 1983/84 on a Beocord 8004 and they still sounds like new on my Beocord 9000
									        Doctor
								                - Joined on 09-14-2010
								                - Posts 555
										    I may be wrong, but I am fairly sure that my old dealer told me that Maxell tapes were more abrasive than most others. I always use TDK myself - usually SA, SA-X or similar.
									        kimberley
								                - Joined on 04-21-2007
								                - London, U.K.
								                - Posts 40
										    TDK SA when possible - I didn't find much improvement with MA - the problem comes with concerts lasting longer than 50 minutes. The auto reverse BeoCord 5500 is a boon in terms of time as the turnover is so fast, but it doesn't (to my ears) quite equal the BC9000. Personally, I didn't like the Maxell 120 chrome tapes, so for longer recordings I tend to use TDK D. I did try the TDK D 180 once, but couldn't 'calibrate' it with the BC9000 and it stretched when fast-wound.
I still find the sound from tape very good when recording broadcast concerts, though a digital hard drive is more convenient - record for hours, then sort out the division onto CDs or cassette tapes later! But the BeoCords with timers are a great advantage for recording when out at work.
        Page 1 of 1 (8 items)
