Latest post 11-12-2010 5:18 PM by kimberley. 7 replies.
Page 1 of 1 (8 items)
  • 11-10-2010 3:01 AM
    What kind of cassette tape do you use?
    Hello fellow Beoworlders, I am wondering which tape, you normally use with your beocords Wink
    I am using the new series of TDK SA-90's, and my parents' old Maxell UDXLII's, and soon some TDK MA Metal tapes
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 11-10-2010 4:11 AM In reply to
    Re: What kind of cassette tape do you use?
    The ones that I happen to have. I think I last bought cassettes in 1990 or so Stick out tongue
    ...and they were mostly TDK SA-X type II it seems, still have a couple in wrappers. Others that have held up well have been Maxell UD-II, Sony UCX-S and from the cheaper ones, Sony HF-ES. I have plenty of Dolby C recordings done on my JVC KD-D50 from 1982 on, and most of them still play great on my B&O decks - and of course the JVC, I still have it.
    -mika
  • 11-10-2010 5:10 AM In reply to
    Hehe, those SA-X are nice tapes, just ordered 40 very cheap assorted chrome tapes, mostly TDK and Maxell Whistle
  • 11-10-2010 2:20 PM In reply to
    Maxell XL II, great tape!
  • 11-10-2010 9:28 PM In reply to
    Maxell UD XLII's were always my tape of choice. I still have a few recordings from the 80's that play well even today.
  • 11-11-2010 3:01 AM In reply to
    The UDXLII's are great tapes, I listen to some tapes recorded in 1983/84 on a Beocord 8004 and they still sounds like new on my Beocord 9000
  • 11-11-2010 6:12 AM In reply to
    I may be wrong, but I am fairly sure that my old dealer told me that Maxell tapes were more abrasive than most others. I always use TDK myself - usually SA, SA-X or similar.
  • 11-12-2010 5:18 PM In reply to
    TDK SA when possible - I didn't find much improvement with MA - the problem comes with concerts lasting longer than 50 minutes. The auto reverse BeoCord 5500 is a boon in terms of time as the turnover is so fast, but it doesn't (to my ears) quite equal the BC9000. Personally, I didn't like the Maxell 120 chrome tapes, so for longer recordings I tend to use TDK D. I did try the TDK D 180 once, but couldn't 'calibrate' it with the BC9000 and it stretched when fast-wound.
    I still find the sound from tape very good when recording broadcast concerts, though a digital hard drive is more convenient - record for hours, then sort out the division onto CDs or cassette tapes later! But the BeoCords with timers are a great advantage for recording when out at work.
