1st March February 2012
Latest post 08-02-2011 5:01 AM by Hiort. 20 replies.
11-01-2010 7:56 AM
Hiort
- Joined on 04-17-2007
- Posts 383
Annoying "Crack" noice from the Beovision 10-40 cabinet?
I experience a quite annoying sporadic noise that probably comes from the cabinet.
It´s easily described as a "small plastic sounding crack noice", similar that I recall one could hear from the plastic cabinet movements when the old CRT TV:s got warm.
It sometimes appear quite soon after switching on the set, and sometimes after like 45 minutes of operation. Once it appear, it "cracks" now and then during e.g. a TV evening.
It´s clearly not from the loudspeaker and its sounds like the cabinets "moves" after its being warmed up.
Has any other BV10 owner experienced this, or are your sets completely silent (apart form the fan)?
/Claes
_____________
Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
1:st prize winner Beoworld January Price Draw.
Dude1
- Joined on 09-18-2007
- London
- Posts 189
Re: Annoying "Crack" noice from the Beovision 10-40 cabinet?
I had a similar issue with a BeoSound 1.
I took it back and requested a refund. It's not what you expect from a quality brand.
Hiort
- Posts 383
Anyone else have these types of sounds from the BV10?
_____________
Doctor
- Joined on 09-14-2010
- Posts 555
Yes, mine did that. Not a huge deal - I agree sounds like something expanding. Mine was on a floor stand.
steve77
- Joined on 05-03-2007
- Posts 5
My wall mounted BV4-50 "cracks" quite frequently. I would also agree the cause to be expansion/contraction
of cabinet.
antspants13
- Joined on 01-29-2008
- Checkley
- Posts 8
I get it occasionally on my beovision 4, 50" too :((
Peter Pan
- Joined on 04-16-2007
- Danmark
- Posts 741
Hiort
I own 2 versions of BeoVision 7-40 " first Mk II and now Mk. III and never the "cracking" problem. YOU should have bought the flagship. B&O factory in Czech "Koprivnice" haven't good Danish glue. ;-)
Dave
- Brisbane, Australia
- Posts 2,328
Peter Pan:
Hiort
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
antspants13: I get it occasionally on my beovision 4, 50" too :((
Just talked to my local dealer, and it is a known issue, i also experience it with my BV4-50", and there is some strips/tape thingy available to the delaers as fix, and i have just told my dealer to get it and install it in my tv, and it is all payed for by B&O :)
Contact you dealer, it is unacceptable with that cracking noise.
/Weebyx
Hiort
- Posts 383
Thanks everyone. Very valuable input.
My dealer have said that they will investigate, and have the local B&O repair shop to visit me.
_____________
Schmedegaard
- Joined on 05-21-2010
- Denmark
- Posts 95
I never had this problem
But glad that your local Bang & Olufsen store is taking care of it.
Great with good service.
BeoGreg
- Joined on 07-24-2008
- South of France
- Posts 139
Peter Pan:
Well, on the back of my BV 10-40 there's a sticker that says : Country of Origin Denmark.
The glue must be danish then !
BTW, I don't know if BV7 is B & O "flagship", but I know It certainly also has a lot of issues.
On the two BV 10 I had, a small cracking noise appeared and disappeared depending on the SW version update (build 127 was without craking noise, build 126 was with it).
I now have build 153 plus the extra anti-cracking noise aluminium plate (serious !) installed on the back of the screen.
I now only hear a crack once in a while, like on every TV, my MX or Avant did a wee crack sometimes...
Cheers,
Gregory
Since 1995 : Beosound Century, Beolink 1000, Beocom 2400, Beovision MX 6000, Beocord VX 7000, Beo 4, LC2, Beosound Ouverture, Beolab 2500, Beocom 6000, Beolab 8000, Beosound 9000, Beovision Avant 32, Keyring, Bottle opener, Beosound 2, A8, Beosound 3, Beovision 10-40, Beo 4 Navigation, BeoTime, Beocom 5, Form 2...
Hiort
- Posts 383
BeoGreg:
Cheers,
Gregory
Thanks Gregory,
Did the dealer install this aluminium plate on your existing set? Did they have to take the TV to a repair shop to do it?
/Claes
_____________
BeoGreg
- South of France
- Posts 139
Hiort:
/Claes
One technician did it at home.
First, unscrew the anti reflect screen (4 screws) and take it off.
Second, unscrew the Samsung screen (yes you can read the brand on it).
Fird, screw the "special aluminium plate" on the holes waiting for it and glue two "special processors plastic squares".
Four, put everything back (be carefull with dust or finger prints under screen) and be surprised how cool the back of your BV10 now is !
It was quick and easy.
Cheers,
Gregory
Hiort
- Posts 383
BeoGreg:
Cheers,
Gregory
Thanks Gregory,
Slightly off topic, but since you mentioned removing the screen above: Is it possible to add "anti reflect" afterwards? I ordered mine without anti reflect screen and I regret that a bit now.
/Claes
_____________
Weebyx
- Denmark
- Posts 321
Had my tv fixed today :)
Two technicians and 1 hour, at my home.
1-2-3 look, it is a panasonic(after the removal of the B&O frame :) All it was about was mounting this...
On the panasonic screen, and the B&O frame, and i havent heart a crack since this morning :)
/Weebyx
Hiort
- Posts 383
Awesome. My dealer have confirmed that my BV10 shall be fixed. I´m waiting the technician to call to make an appointment.
In one of the posts above, something more techy is described, rather than this "foam tape".
Wonder how they will fix my TV
_____________
Hiort
- Posts 383
Bumping my old thread up, for information.
As I have told in this thread, I had my BV10 retrofitted to fix heat related noices form the cabinet.
The retrofit helped a lot, but there are still sporadic "cracks" or "click" noices from the cabinet especially during the first two hours of viewing.
My dealer has been very helpful in finding solutions and driving the case towards Struer.
My dealer says he have sold a lot of BV10s but no other customer have reported any problems like that.
Struer have said that they have one other customer case where they have not been able to cure the problem with the retrofit that was made on my set. They now say that they will have a solution for me within 3-4 weeks.
If that does not cure the problem, my set will be replaced under warranty.
_____________
Page 1 of 1 (21 items)
