1st March February 2012
Latest post 11-13-2010 2:23 PM by Leslie. 21 replies.
10-31-2010 2:23 AM
adatia
- Joined on 03-31-2009
- Posts 5
Beovision AV9000 switches off after 5 mins of viewing.
Hi, need some advice, I have an AV9000 which has been a joy, had it for 15 years now, and last year the TV decided to pack up, basically wouldn't power on. Now the TV has started to turn itself off after a few minutes (5 mins) of viewing. Is this a common fault or just the age of the TV and sadly time to give up and replace the TV? Just seems that repairing it now every 12 months isn't going to be economical.
If I do replace, any recommendations, I want to keep the speakers (Penta 3 and 8000), but I guess the masterpanel would need to go.
davefarr
- Joined on 08-21-2007
- France
- Posts 190
Re: Beovision AV9000 switches off after 5 mins of viewing.
This has been covered in a post earlier this year and the cause was a simple dry solder joint which took 30 minutes to find and rectify. Don't give up on your AV9000 for the sake of a few pounds if it's your joy.
Dave.
Am I ready? I was born ready!
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Spiros:Starting from the end, the Master panel can work with newer systems with a small trick. A BO tech can put it in test mode (I don't remember the way but contact me and will send you the instructions).
Hi Spiros,
Can you tell me what that trick is. Since I have 4 of these units I 'm really curious..
Have tried before to connect the Masterpanel directly to an Avant and it was playing but unfortenately no display functions on the masterpanel.
Thanks, Leslie
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
adatia
- Posts 5
Thanks Spiros, that is useful. I am debating the repair, but also considering purchasing a used one. It looks terrific and I have the usual fla panels in other rooms, but, this setup has always been special. Its just the practicality and economics of repair. The last time cost £500 including pickup and delivery.
adatia
- Posts 5
Agreed - I am now inclined to go for the repair again. I'll search for the post as well. If there's a link for the service manual anywhere that would be helpful. Thanks again for the posts!
Leslie
- Netherlands
- Posts 2,201
Spiros, thank you for sharing these hintfull tips!
One more question though about the Masterpanel , does that mean the functionality of the display and keyboard can be used?
Leslie
davefarr
- France
- Posts 190
To the original poster (adatia)- where are you?. If you're in the South of the UK, I may be able to give you the number of someone who can come to your house to look at it. He's done this already with another AV9000 owner who was going to sell hers as non-working but he fixed it in 30mins.
Dave.
Spiros
- Joined on 09-03-2007
- Thessaloniki GREECE
- Posts 1,088
Leslie:Spiros, thank you for sharing these hintfull tips!
Leslie
Hi Leslie,
All buttons work perfectly on the MCPAV and you also see the source etc.
Best regards
Spiros
adatia
- Posts 5
Dave I'm in London, SW10. Thanks for your help.
davefarr
- France
- Posts 190
I've sent you a PM with the engineers contact info.
Dave.
Leslie
- Netherlands
- Posts 2,201
Spiros:Hi Leslie, All buttons work perfectly on the MCPAV and you also see the source etc. Best regards Spiros
Thank you Spiros! Great
Spiros
- Posts 1,088
Leslie: Spiros:Hi Leslie, All buttons work perfectly on the MCPAV and you also see the source etc. Best regards Spiros
You are more than welcome. Let me know if it did work out for you.
Best regards
Spiros
Leslie
- Netherlands
- Posts 2,201
Spiros:Let me know if it did work out for you. Best regards Spiros
Hi Spiros,
To good to be true, it did not work! Made the link on the ML connector internally as you said (4 and 6) but no control and display on the Masterpanel. In fact, it doesn't make any difference with or without the link. It can be controlled via the Avant though but not by the Masterpanel itself Did I missed something beside soldering a link?
Leslie
- Netherlands
- Posts 2,201
Spiros:Maybe you can contact our member Ulf directly (usually posting on the German section) and discuss it with him.
Hi Spiros,
Placed a new thread on the German forum. Hopefully my German is ok and will Ulf respond!
Leslie
- Netherlands
- Posts 2,201
Spiros, maybe you can help finding him on the German forum
Page 1 of 1 (22 items)
