Latest post 11-02-2010 5:57 AM by hagan. 4 replies.
Page 1 of 1 (5 items)
  • 10-30-2010 4:07 PM
    • AdiS
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Posts 196
    Turning Film Mode off on BeoVision 10-40
    Hello together,
    please can anyone tell me how I can turn off the Film-Mode on BV 10-40? I tried doing it like on the Avant but there is no menu called setup like on the Avant.
    Thanks for you help
    regards, Adrian
  • 10-30-2010 4:20 PM In reply to
    Re: Turning Film Mode off on BeoVision 10-40
    Access the Connections Menu and press Red  and Go at the same time. You will enter the user service menu. You have two options - Monitor Information and Adjustments. The Film Mode, and a fair amount besides, are in the Adjustments menu.
  • 10-31-2010 4:08 PM In reply to
    Red and go doesn´t work for meSad
    Does the latest version use a different command
  • 10-31-2010 7:36 PM In reply to
    on the BEO4:
    1. Press "TV"
    2. Press "menu"
    3. Press "0", "0", "GO"
    4. Go to Monitor settings and then to the scaler settings. In the list you see a setting 'Film Mode'
    Succes!
    Harry
  • 11-02-2010 5:57 AM In reply to
    Menu 0 0 GO did the trickBig Smile
