Hello together,
please can anyone tell me how I can turn off the Film-Mode on BV 10-40? I tried doing it like on the Avant but there is no menu called setup like on the Avant.
Thanks for you help
regards, Adrian
Access the Connections Menu and press Red and Go at the same time. You will enter the user service menu. You have two options - Monitor Information and Adjustments. The Film Mode, and a fair amount besides, are in the Adjustments menu.
Red and go doesn´t work for me
Does the latest version use a different command
on the BEO4:
Succes!
Harry
Menu 0 0 GO did the trick
