Latest post 10-31-2010 3:37 AM by stotty1111. 10 replies.
Page 1 of 1 (11 items)
  • 10-30-2010 9:38 AM
    Just a couple of questions...
    Hello Guys (and maybe girls),
    Couple of quick queries.....
    1. How do I add 'phono' to my Beo4. I've been into 'add' and scrolled through quite a long list of possibilities - but 'Phono' doesnt appear. My earlier Mk.1 beo4 had phono in it's list, but not this newer one....?
    2. How do I pull up the Service Menu on a BV5 and on an Avant, and on a MX4000. When i say service menu, I'm wanting to look at the statistics of how many times set has been turned on/off, how many hours its been in use etc...?
    Cheers guys..
    Michael
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
  • 10-30-2010 10:21 AM In reply to
    Re: Just a couple of questions...
    It doesn't appear in some s/w issues. Try N RADIO, it's the same command!
    Regards Graham
  • 10-30-2010 12:27 PM In reply to
    joeyboygolf:
    Thanks for your suggestion Graham, but I dont seem to have N.Radio, I have N.Music option - tried that & that switched on Tape2 rather than phono....
    Any more ideas..?
    And can anyone help with the Service Menu on my tv's...? (as in hours many hours use they've had etc..)
    Cheers
    Michael
    BS 7000, BS 5500
  • 10-30-2010 12:39 PM In reply to
    For the Bv 5 try....Menu 0,0 then press go,should bring up the service menu!
    Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
  • 10-30-2010 3:25 PM In reply to
    Bv7Mk3:
    Thanks for your try, but....
    Nope, that doesnt work either.........that bring up timer settings....
    Anybody else got any ideas on either issue.?  1) Phono adding on Beo4  2) Bring up the service menu on bv5, Avant & mx4000...?
    Cheers,
    Michael
    Michael
    BS 7000, BS 5500
  • 10-30-2010 4:00 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    IS A AUX LISTED if it is does that work?
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 10-30-2010 4:15 PM In reply to
    stotty1111:
    tony
    Big SmileHa ha...thanks Tony...but no that doesnt work either. 'A AUX' comes on my penta displays but wont turn on my phono.
    Didnt think it would be difficult one for you B & O experts...hahahaBig Smile
    Any more ideas at all...anyone...?Stick out tongue
    Michael
    BS 7000, BS 5500
  • 10-30-2010 4:29 PM In reply to
    Service menu: Start with the set off. press in the following order:
    TV
    MENU
    scroll down to SET UP
    GO
    then press 0 0 GO quickly. You will be in the service menu. ( DON'T PLAY WITH THE SETTINGS! Smile )
    On the Beo4, you need to add N.Radio to your LIST. Which Beo4 do you have? Normally, you just press stand by and LIST at the same time. Scroll to ADD? and press GO. Press LIST to scroll through the choices. The relatively old version I have gives me the choice of both PHONO and N.Radio, which as Graham quite rightly says is the same actual command.
  • 10-30-2010 8:40 PM In reply to
    Ooops forget that bit in my answer...set upWhistle
  • 10-30-2010 9:34 PM In reply to
    Ohh thanks guys - i got it now.
    Yes N.Radio works the phono now.
    And I've got into the service menu on my BV5, I will try the same thing on my other two sets, just out of interest.
    Many thanks to you guys.
    Michael
    Michael
    BS 7000, BS 5500
  • 10-31-2010 3:37 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Having now thought about it I had the same problem some time ago with one of my setups, didn't get resolved, but may be a software problem however reverting back to a bl1000 solved it ie shift radio - maybe if you have shift listed then that might work with radio to bring up phono give it a whizz
    t
