Latest post 10-30-2010 1:31 PM by arned. 8 replies.
Page 1 of 1 (9 items)
  • 10-28-2010 11:24 AM
    Beosound 3000 - Help
    My BS3000 which was bought new and about five years old has had little use of the CD, however now when I try to play a CD it constantly says Load CD - I have tried to power it off and on but this hasn't helped. Is there anything I could check to see if it's just something that's stuck. The disk spins up but nothing else happens and load cd comes up more or less straight away. Does it need a visit to the repair shop?
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 10-28-2010 1:16 PM In reply to
    Re: Beosound 3000 - Help
    Try with another good cd, not a burnt copy, and clean the laser lens carefully with a cotton swab.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 10-28-2010 1:22 PM In reply to
    Hi - I've tried with a few, but will try cleaning the lens
  • 10-28-2010 1:32 PM In reply to
    If cleaning does not help, pull the plug and wait some 3 min. and start up again.
  • 10-28-2010 1:34 PM In reply to
    Since the cd spins up, I would suggest that it is not a dirty lens as the cd mech must be finding focus.
    I guess that this is a cd interface fault which requires expert intervention or a replacement cd mech kit by a service centre.
    Regards Graham
  • 10-28-2010 2:24 PM In reply to
    • Dude1
    • Top 500 Contributor
    • Joined on 09-18-2007
    • London
    • Posts 189
    Oh this old chestnut...
    Yes, it needs a visit to the Bang DR. Mine has done the same thing after being in extended storage. Essentially the CD mechanism has died. The mechanisms needed to be used regularly as a batch of lubricant for some of the mechanisms is prone to hardening and not allowing the CD lens to move correctly.
  • 10-29-2010 3:03 PM In reply to
    • arned
    • Joined on 04-24-2007
    • Denmark
    • Posts 97
    My BS3000 did the same after about 4 years. There was only one thing to - repair shop - and a new CD-unit.
  • 10-29-2010 3:06 PM In reply to
    Yes, definitely a new CD mechanism required...easy fix, but parts not cheap!
  • 10-30-2010 1:31 PM In reply to
    • arned
    • Denmark
    • Posts 97
    Yes, - and the reapir is not for a home made "handyman".
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
