1st March February 2012
Latest post 10-30-2010 1:31 PM by arned. 8 replies.
10-28-2010 11:24 AM
ajames
- Joined on 05-04-2007
- Posts 275
My BS3000 which was bought new and about five years old has had little use of the CD, however now when I try to play a CD it constantly says Load CD - I have tried to power it off and on but this hasn't helped. Is there anything I could check to see if it's just something that's stuck. The disk spins up but nothing else happens and load cd comes up more or less straight away. Does it need a visit to the repair shop?
Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Try with another good cd, not a burnt copy, and clean the laser lens carefully with a cotton swab.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
ajames
- Posts 275
Hi - I've tried with a few, but will try cleaning the lens
Søren Mexico
- Mexico city
- Posts 1,621
If cleaning does not help, pull the plug and wait some 3 min. and start up again.
Dude1
- Joined on 09-18-2007
- London
- Posts 189
Oh this old chestnut...
Yes, it needs a visit to the Bang DR. Mine has done the same thing after being in extended storage. Essentially the CD mechanism has died. The mechanisms needed to be used regularly as a batch of lubricant for some of the mechanisms is prone to hardening and not allowing the CD lens to move correctly.
Page 1 of 1 (9 items)
