I believe using it without speakers is exactly your problem... for some odd reason, B&O decided that if it doesn't have any Powerlink speakers connected, it will drop to Option 0 after each power cycle.
There was some connector trickery (a fake "speaker") that would fool it, but in the meantime, just keep it plugged in! Now you know at least that it is not broken
