Latest post 10-11-2010 7:50 AM by chartz. 29 replies.
Page 1 of 2 (30 items) 1 2 Next >
  • 10-06-2010 8:01 AM
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Shot Beogram 4002 bearing?
    The title says it all.
    I got a white Beogram 4002 whose bearing has considerable play in it.
    What I don't understand is that there is no visible wear anywhere.
    Could it be that something is missing? It looks exactly like the picture shown on this post. There is no oil or grease inside.
    Any ideas?
    Jacques
    Jacques
  • 10-06-2010 8:07 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Shot Beogram 4002 bearing?
    It will almost always wobble a bit if dry.
    Try adding a little grease.
  • 10-06-2010 8:15 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks.
    What kind of grease?
    Jacques
    Jacques
  • 10-06-2010 8:31 AM In reply to
    • Dillen
    • Posts 5,008
    It's not very critical.
    I don't remember what the manual prescribes but I use a standard ball-bearing type
    with a not too high viscosity and not too runny either.
  • 10-06-2010 8:37 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Well then it's not a bit wobbly. I'd say the play is not far from 1mm side to side. The problem seems to reside at the bottom of the bearing, where there's nothing to hold it it seems!
    Jacques
  • 10-06-2010 8:47 AM In reply to
    • Dillen
    • Posts 5,008
    I suggest you try the grease.
  • 10-06-2010 8:51 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Of course. Do I have to fill it up?
    Jacques
    PS. I'm getting accustomed to the MC120.2, as the sound now seem to be better, (?)with a bit more of everything. Piano is delightful, as voices are!
    Caps run-in period? Do you believe in this?
    Jacques
  • 10-06-2010 9:28 AM In reply to
    Dillen:
    The manual prescribes Esso Nuto H43 Hydraulic oil which is no more viscous than SAE 40 engine oil and certainly not as viscous as any grease that I am used to.
    Regards Graham
  • 10-06-2010 10:22 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    My main concern is that the bearing is not held at its bottom. Do I miss something? Adding oil or grease doesn't make any difference. The play just seems excessive. What is wrong then? The lower part of the shaft is allowed to move freely and it shouldn't be so, should it?
    Jacques
    Jacques
  • 10-06-2010 10:30 AM In reply to
    For what it's worth, every single deck of this type I've seen had a wobbly platter bearing.
    -mika
  • 10-06-2010 10:39 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    It's worth a lot!
    So it's a particular design then.
    Maybe the platter weight along with the belt tension compensate the play somehow... Odd design! The elasticity of that belt must be very critical.
    Jacques
    Jacques
  • 10-06-2010 10:43 AM In reply to
    • Dillen
    • Posts 5,008
    It's a bronze bearing so anything from SAE30 and up should be fine.
    SAE30 or similar oil is good if you can press it into the pores of the sintered bearing
    material but that is a process that most people cannot do at the kitchen table
    so I normally recommend a not-too-thick-grease. That's far easier to handle without
    making a mess, it stays where it is put and it works fine.
    Yes, they are all a bit wobbly, even more so if dry. It should not wobble around when rotating
    by itself or when driven by the motor but it will almost always wobble a bit if
    the platter is pressed with your fingers.
    Or maybe they were just all worn! Smile
    In any case, I haven't noticed it causing any ill effects on my decks - the platter seems to run completely stable anyway. They don't have much grease left either.
    -mika
  • 10-06-2010 11:01 AM In reply to
    • Step1
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I have noticed the AC motor bearing (at least in my 4000) is a much higher tolerance! However as others have said while there is play in the bearing it is unoticable when the platter sits on top and you use the player. As long as the platter sits level then all should be well.
    You will have to tell us what you think of your new deck when set up :)
    Olly.
  • 10-06-2010 1:41 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Right then.
    When I press Play the platter turns but when I release the button it stops. Nothing else happens. Ah yes if I press play and keep it that way I can select 45 rpm.
    That's it.
    Any hints please?
    Jacques
    Jacques
  • 10-06-2010 2:13 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Check that the servo belt is still in place and not slipping under the right hand panel.
    Olly.
  • 10-06-2010 2:26 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks. The belt is in place and the carriage motor doesn't turn at all (no voltage arrives at it either).
    There is 5v at IL1 but I can't see any light. Should I see some?
    Jacques
    Jacques
  • 10-06-2010 2:51 PM In reply to
    • Dillen
    • Posts 5,008
    The servo motor should start rotating when you press START (or PLAY as the lettering says on some decks).
    If it doesn't, you will have to find out why.
    Check for cracked solder joints at the main board edge connectors.
    Check the power supplied to the main board.
  • 10-06-2010 4:23 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Dillen:
    Even if the IL1 lamp is dead?
    Jacques
  • 10-06-2010 4:45 PM In reply to
    • Dillen
    • Posts 5,008
    I believe so.
    So you have two faults still. Isn't it wonderful ? Laughing
  • 10-07-2010 2:43 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Hello, Should I hear a click when I press play? Jacques
    Jacques
  • 10-08-2010 4:24 AM In reply to
    Yes!
    Regards Graham
  • 10-08-2010 4:36 AM In reply to
    • Dillen
    • Posts 5,008
    No.
  • 10-08-2010 4:39 AM In reply to
    • Dillen
    • Posts 5,008
    The platter should start rotating and the carriage should start moving left.
    No clicks.
    First click will be from either the solenoid lowering the tonearm (in the case
    of a 12 inch record) or the speed switching relay (in case a 7 inch
    record (or no record) is found).
  • 10-09-2010 6:34 AM In reply to
    My 6000 clicks, which I think is the end stop microswitch deactivating!
    Regards Graham
