Keith thanks for response
I am running 3.87
Not sure about deletion. I used DVT2 as that is what is defined on my BV8-40 for foxtel STB. When I went to start putting logos DVT2 was not available on the config tool Logo tab, only TVand nradio available. Interestingly DTV was not there either. In edit screen I copied channels button from TV to DTV2 submenu, found DVT2 was now on the Logos tab and then moved logos individually from the Australia TV template. I added the INFO button to the first submenu page with code and worked fine. Copied to the channels page and can't get it to work
I have BV8-40. What I mean by the PUC control is in the BV8 menu you choose the connection AV1 in my case, select IR socket PUC 1 and next screen choose Foxtel digital cable STB. When used like this it puts a menu (from menu button on beo4 or 5) on screen, choose 6 for info on beo4 or push programed Info button on beo5.
