Latest post 10-10-2010 11:08 AM by Søren Mexico. 17 replies.
Page 1 of 1 (18 items)
  • 09-30-2010 5:43 PM
    S 45 Speakerstand, DIY
    How to make your own speaker stand
    Cut to size
    Weld all 4 corners, ajust 90 degree angle
    Ajust inclination of upright to +- 3 degree, grind, paint
    Finished with brass busher and ajustment screw.
    1/2" x 1" 18 gauge Steel USD 8.00
    1 can Hammered spray paint USD 8.50 (used 1/3 for 2 stands)
    Screws and odd pieces found in my workshop.
    Next week I go to MacAllen to pick up my equipment
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 09-30-2010 6:09 PM In reply to
    • Jon
    • Top 500 Contributor
    • Joined on 03-05-2009
    • Posts 138
    Re: S 45 Speakerstand, DIY
    That's awesome! Hat's off to you!
    Jon
  • 10-01-2010 1:21 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Very nice !  Yes -  thumbs up
  • 10-01-2010 6:34 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    You're my kind of BeoFan!
    Excellent!
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 10-01-2010 9:42 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Nice, professional clean job - I can see future orders for you :)
    Olly.
  • 10-01-2010 12:08 PM In reply to
    Well done, Soren!
    • B&o bottle opener
  • 10-01-2010 12:13 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Fantastic! Yes -  thumbs up
    Now show off and do some trumpet standsLaughing
    If you think nobody cares, try missing a couple of payments.
  • 10-01-2010 12:15 PM In reply to
    Stonk:
    LaughingLaughingLaughingLaughing
    • B&o bottle opener
  • 10-01-2010 12:26 PM In reply to
    I've been thinking about that, will start looking for an old Bass Tuba to start withSmile
    burantek:
    Stonk:
  • 10-01-2010 12:42 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Brilliant - great attention to detail with the angle & adjusterYes -  thumbs up
    Chris.
  • 10-01-2010 1:14 PM In reply to
    Love these!
    Is the top end (the attachment to the horizontal bar) different in 45 stands and the bigger ones, or is that small horizontal "step" your own idea? In any case, I like these more!
    -mika
  • 10-01-2010 2:18 PM In reply to
    tournedos:
    Love these!
    Somewhere on the forum there is some drawings with measurements, but without the "nose", on Ebay I saw a pic of presumed S 45 stands with a (smaller) "nose". As I'm waiting (and bored) for a pair of S45s I started to think about it, Speaker footprint is 265 Mm wide, 200 Mm deep, size of foot found on forum is 265 x 255, if I put the crossbar directly on the upright, the S45 will hang about 50 Mm behind the front of the stand, and thats bad design, the nose is with crossbar 30 Mm, this distance computed with the newest cientific knowledge (one eye closed and my thump) this will bring the bottom edge of the speaker to the front of the stand when pointed a little upward. My stand has the footprint 265 x 250 Mm, So if you make your own stand, wide= speaker wide, deep= speaker deep + 20 Mm and crossbar directly on upright, or "nose" and deep= speaker + 20 +nose. If the speaker weights more than 12 Kg I recommend 3/4" x 1.1/4" 18 gauge steel. I have welded the upright to the foot, it should be attached by a M6 screw, but its difficault to make without a lot of work.
    Homedepot has felt or plastic pads to glue under the stands.
    The brass bushers: Hole on crossbar is 10 Mm crossbar 5 Mm thick, busher is 8 x 7 Mm where it through hole attach to speaker and 15 D x 9 with sinkhole for M5 Allen screw behind crossbar. this should give enough play for inclination ajustment. Ajustment screw is M5 allen, head pressed into brass, I did these brass details just because I could.
  • 10-01-2010 2:29 PM In reply to
    Forgot to mension: when I have my speakers here, I will make 2 holes in the upright for cables.
  • 10-01-2010 3:07 PM In reply to
    Søren Mexico:
    Now that you mention it... can't understand why B&O didn't think of it!
    Might be difficult to thread it with a connector attached, but even that could work with just a slot in the bottom of the vertical bar and another beside a removable top cap...
    -mika
  • 10-01-2010 3:38 PM In reply to
    tournedos:
    Søren Mexico:
    Well, I can fix anything
  • 10-01-2010 5:46 PM In reply to
    • Dillen
    • Posts 5,008
    The stands came in many different versions.
    Some are completely welded and handles as one piece, others have a screw
    from below that holds the square frame to the vertical part and can be taken apart for easy
    storing or shipping.
    Some are welded closed at the top of the vertical part, others have a plastic top inserted.
    Finally, the height is different from the first series of Uniphase speakers to the second
    and again from S45 to S80 etc.
    The stands for Beovox M70/75/100 are black and have a larger square.
    And, apart from a few of the black ones, they have no markings.
    It's a jungle, really.
  • 10-09-2010 7:43 PM In reply to
    • BoxOPwn
    • Not Ranked
    • Joined on 05-07-2010
    • New England
    • Posts 21
    The stands for my s80.2's have small plastic feet on the bottom, I don't know if these are found on all of the different stands. One of them is missing from my stands, and I would like find a suitable replacement. Does anyone know were such a part could be found?
    If I can't find a similar part, I could easily just make one from some plastic rod.
  • 10-10-2010 11:08 AM In reply to
    BoxOPwn:
    Check in Home Depot, they have glue on pads in different sizes and materials.
