Latest post 09-27-2010 11:29 AM by stotty1111. 6 replies.
Page 1 of 1 (7 items)
  • 09-24-2010 2:25 PM
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    MCL2P Mute
    I have an MCL2P connected to a BeoCenter 2300 with a Mk 2 Powerlink cable.  When I mute the BeoCenter, the MCL2P does not mute.
    To rule out a BeoCenter fault, I connected the MCL2P to my BeoCenter 9500 but the same thing happened.  Is the MCL2P faulty or does it simply not mute in this configuration?  (Does it only mute when used with an MCL2AV?)
    I'd appreciate help!
  • 09-25-2010 7:20 AM In reply to
    Re: MCL2P Mute
    There is no internal muting in the MCL2p,just power up/down,like in the Beolab 8000.The signal lines are muted within the Beocentre when changing source etc.I think it was only the Beolab Penta and Beolab 3500/4500/5000 that have internal muting.
    I've used the MCL2p as a slave amplifier to drive speakers in a link room,and you can connect a MCL2a(Extra speaker kit)to the MCL2p,and then local muting is available within the relay box.Works very well.
    It's a useful amp,and of course saught after.
    Regards,
    Nick
  • 09-25-2010 2:39 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: MCL2P Mute
    will also work as a slave off a beolink active box connected to the source by masterlink - then you can use the ir eye to control it!
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 09-27-2010 8:36 AM In reply to
    • Guy1680
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Re: MCL2P Mute
    Many thanks both Nick and Tony.  I guess I won't be taking it to bits to fix anything then!  I'll probably keep using it as an amp for the 2300 until I can afford some active speakers - maybe Beolab 2500s.  I presume that a Beolink passive also doesn't mute - given that it's a modified MCL2P?
    I suppose I could rig up an MCL2A but that seems a bit silly within a single room - guess I'll just live with the lack of a mute function.
    Thanks again for your help
    Regards Guy
  • 09-27-2010 9:18 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: MCL2P Mute
    without checking does the passive have an ml sockety if it does then with an ir eye should be ok - i only have an mcl 2p and a couple of ml/mcl converters hence my use of an active to trigger the passives
    tony
  • 09-27-2010 10:05 AM In reply to
    • Guy1680
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Re: MCL2P Mute
    I don't have a Passive - just an MCL2P.  I was just wondering whether to start looking for a Passive.   Thanks anyway,
    Guy
  • 09-27-2010 11:29 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: MCL2P Mute
    sorry for the misunderstanding my fault i meant that the passive might have a masterlink connection and have checked, yesn it does so get the piggy bank fired up!!
    tony
