Latest post 09-24-2010 4:51 PM by elephant. 5 replies.
Page 1 of 1 (6 items)
  • 09-24-2010 12:45 AM
    Beosound 3 + remote
    Hi
    Is it possible to control a beosound 3 with Beo4?
    br
    /h
  • 09-24-2010 12:50 AM In reply to
    Re: Beosound 3 + remote
    No. [:'(]
    BS 1, BeoCom 2, 2x LC 2, Form 2,  BS 2, BS 3, 2x Beo 4, BS 5, BM 5, BL 5,Beo 6, BS 6, 2x A8, BV 8-40, BL 8000, 3x A9 Keyring, Serenata, BeoTime, BeoTalk 400
  • 09-24-2010 4:19 AM In reply to
    • GOLFGEAR
    • Not Ranked
    • Joined on 04-24-2007
    • Sydney Australia
    • Posts 17
    I dont undersand why it was designed without control with Beo 4 or Beo 5 as B&O philosophy  is ease of use and integration.
  • 09-24-2010 12:07 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Clearly I have no clue as to the actual design decision, but, as conjecture, I'd say that it is small and portable so it can always be close at hand... it is it's own remote control Smile...  nothing easier than that!  In fact, it probably doesn't weight that much more than a Beo4 Surprise
  • 09-24-2010 12:28 PM In reply to
    I agree with you, Stan - there's not much need for a remote receiver on an "up-close" portable device, and if it had one (no problem technically, and not very expensive either), the forum would be full of questions on how to disable it! It would be highly annoying to have your Beosound 3 turn on as well when you want to listen to radio on your main system...
    -mika
  • 09-24-2010 4:51 PM In reply to
    tournedos:
    Laughing Laughing Laughing Laughing Laughing Laughing Laughing
    so true
    we are perfect pedants
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
