Hi
Is it possible to control a beosound 3 with Beo4?
br
/h
No. [:'(]
BS 1, BeoCom 2, 2x LC 2, Form 2, BS 2, BS 3, 2x Beo 4, BS 5, BM 5, BL 5,Beo 6, BS 6, 2x A8, BV 8-40, BL 8000, 3x A9 Keyring, Serenata, BeoTime, BeoTalk 400
I dont undersand why it was designed without control with Beo 4 or Beo 5 as B&O philosophy is ease of use and integration.
Clearly I have no clue as to the actual design decision, but, as conjecture, I'd say that it is small and portable so it can always be close at hand... it is it's own remote control ... nothing easier than that! In fact, it probably doesn't weight that much more than a Beo4
I agree with you, Stan - there's not much need for a remote receiver on an "up-close" portable device, and if it had one (no problem technically, and not very expensive either), the forum would be full of questions on how to disable it! It would be highly annoying to have your Beosound 3 turn on as well when you want to listen to radio on your main system...
-mika
tournedos:the forum would be full of questions on how to disable it!
so true
we are perfect pedants
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
