1st March February 2012
Latest post 09-12-2010 1:51 PM by lano. 7 replies.
09-12-2010 9:08 AM
lano
- Joined on 04-25-2010
- Posts 66
Hi, does anybody know what TV screens that can be used together with a Beosystem 1 EU?
The specification says RGBHV 575p 50 Hz, but most screens will only take 60Hz on the PC-input (D-sub)!?
Is there any settings on the Beosystem 1 that will make it work together with “normal” screens that only takes 60Hz?
Is there any converter/scaler available for a decent price?
I plan to use the Beosystem 1 to get surround sound + using the RGBHV out for SD channels, while when watching HD channels I will use a HDMI cable directly from the STB to the screen. Of course it’s possible to always use the HDMI, but it would be good to be able to use the menus etc from the Beosystem 1 (therefor the need for RGBHV out).
Regards/lano
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Panasonic Professional Displays TH-42PF11 or TH-42PH11 or simimlar.
I am using a TH-42PWD6 with a Beosystem 2.
Best regards
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
lano
- Posts 66
kallasr
- Posts 1,077
Page 3:
625(575)/50i or 625 (575)/50p
Ralf
lano
- Posts 66
Thanks, now I know what to look for!
Do you use the D-sub (PC-input) connection?
kallasr
- Posts 1,077
Yes, only connection I use for SD SAT reciever (via Scart to Beosystem 2).
Beosystem 2 via VGA cable to the VGA (PC in) port of the display.
You could connect a HD player etc. directly to the Plasma and use a IR cable to control the player and tell the plasma to switch to DVI when needed. You should download the Manual/service manuals for Beovision 4, Beosystem 1 to 3 etc. from this site to get more knowlegde about how to set the system up.
Ralf
Page 1 of 1 (8 items)
