Latest post 07-30-2011 4:34 AM by joeyboygolf. 72 replies.
Page 2 of 3 (73 items) < Previous 1 2 3 Next >
  • 03-17-2011 12:29 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 7000 tone arm assembly not moving
  • 03-18-2011 2:51 AM In reply to
    Make a piece of square 10-12 Mm. aluminum, hole for shaft to fit, and in the buttom of the piece a 4 or 5 Mm threaded hole, fasten piece from below with 4 or 5 Mm screw with washer.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 03-18-2011 4:21 AM In reply to
    The problem here is that the end of the rod should be positioned exactly, so fabricating a new holder will be difficult or at least time consuming without a good set of tools.
    Since the other half of the original clip is still there, I would still try the hot glue method; just hold the rod in place until the glue sets. If this doesn't work, it takes about one minute to revert, and you can then try the spare clip from Martin.
    -mika
  • 03-18-2011 6:49 AM In reply to
    • Wings
    • Top 200 Contributor
    • Joined on 04-17-2007
    • Hong Kong
    • Posts 341
    Thanks, all.
  • 03-18-2011 7:50 PM In reply to
    tournedos:
    In Hong Kong they copy Rolex, Georg Jensen and who knows what, to copy a crap piece of plastic you only need a mec. work shop or mecanic he will do it on his lunch break for 10 HK $, or Remimbin or what they use these days Big Smile
  • 03-19-2011 4:02 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Ha, ha, ha.  True but this piece of plastic clip is not worth the effort of the copycats.  :)   The minimum wage in Hong Kong will be HK$28 starting in May so prices of the forgeries will be going up.  ;)  :)  I will have to go across the border to the PRC to get it done cheaply after May.  Ha, ha, ha.
  • 06-18-2011 4:09 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Dear All,
    After much further procrastination [mainly because of being intimidated by the unknown], I have re-assembled my BG7000.  The tonearm carriage moves the full length of travel when pushed manually.  However, the deck does not function.
    I now have the following problems:
    1.  when I removed the MMC 2, the tone arm raised up.  After re-installing the MMC 2, the tone arm is not parallel to the deck.  Rather, the tone arm is pointing downwards with the MMC 2 touching the deck.  I tried the "Lift" button out of desperation but that effort failed.
    2.  The tonearm carriage still does not move automatically whether or not there is a record on the platter.
    What did I do wrong?  What should I do now?
    Apologies for all the questions.  Thanks in advance for the advice.
    Yours,
    Wings
  • 06-18-2011 4:36 AM In reply to
    There's this white plastic bar, alongside the rear metal rail of the carriage, that should flip and take care of lowering and raising the tone arm. It has a tiny return spring at one end (the side of the deck as I recall) and it can easily slip out.
    Another possibility is that while installing the arm carriage, you have placed the aforementioned bar on the wrong side of the lever that controls the tone arm.
    Don't try operating the deck until this is sorted. The arm should be horizontal when the mechanism is in the stop position.
    EDIT: the spring is actually visible in your last picture on the previous page, top right third in a recess in the bottom plate. It should pull the white bar so that it stays against the steel wire control rod (coming from the gear mechanism) on the other end of the white bar.
    -mika
  • 06-20-2011 1:36 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Thanks, Mika.  I will check it out and report back.
  • 06-23-2011 7:44 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Hi, Mika.
    I have checked the BG7000.  Things were as pictured until I touched the little spring while testing the connect.  It has now become detached from the white plastic thing.  What should I be doing now?  There does not appear to be a hook on the white plastic to attach the spring.
  • 06-23-2011 8:25 AM In reply to
    I can't see why the hook would come off... it's really small though, and as I recall the spring needs to slightly wrap around the plastic to reach it. I think it took me 15 minutes of frustrating efforts with all kinds of small pliers and pins to reattach it Lightning
    -mika
  • 06-23-2011 7:49 PM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    I will try to post photos of the current situation this weekend [or Monday if I have trouble uploading the photos].
    Thanks.
  • 06-26-2011 10:06 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Photos attached.  Sorry for the poor quality; I used my cell phone camera.
  • 06-26-2011 10:09 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Here's another photo.
  • 06-26-2011 10:10 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    And the last photo for now.
  • 06-26-2011 10:43 AM In reply to
    This is all from memory and it's hard to tell from the photos, but I believe the peg that should hold the spring is still here. There's not much of a hook to speak of, and that's why the spring is so eager to slip out.
    Also, to me it seems the bar has flipped too far to the back, which won't help in keeping the spring in place. How is the control rod at the other end? Is it going to pull the bar towards the mechanism (the center of the deck, against the force of this small spring) or is it currently on the wrong side of it?
    -mika
  • 06-28-2011 3:43 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Thanks for the comment.  I do not know but will try to take more photos to show you.
    In the meantime, here (hopefully) are some better photos.
  • 06-28-2011 3:54 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    And another perspective:
  • 06-28-2011 3:57 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
  • 06-28-2011 4:11 AM In reply to
    These are good pics. As far as I can see, everything is still there. Just put the spring back in place around the round peg in the white plastic whateveritis. (takes a bit more time than saying it)
    What about the other end with the control rod?
    -mika
  • 06-30-2011 5:10 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Here are some more photos.  I tried to get 360 degree coverage in the following photos in order to make diagnosis easier.
  • 06-30-2011 5:11 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Here is another top view.
  • 06-30-2011 5:13 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Photo number one of two from the right.
  • 06-30-2011 5:19 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    A photo from the back.
  • 06-30-2011 5:20 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Another from the back.
