Latest post 06-13-2011 7:57 AM by mrjones. 43 replies.
Page 1 of 2 (44 items) 1 2 Next >
  • 09-08-2010 6:26 AM
    • Clive
    • Not Ranked
    • Joined on 09-05-2010
    • Adelaide Oz
    • Posts 22
    Beocenter 9300 cd fault
    The cd doesn't spin after accepting a disk and the door then reopens.  I've tried a very light clean of the laser lens to no avail.  Are there any common faults or simple checks I could do with a meter for example before admitting defeat and taking it to the local store for a mechanism change out? 9300 is a type 2520, SW1.3, serial number 11684776.
    Hope someone can help, Regards, Clive
  • 09-08-2010 1:20 PM In reply to
    Re: Beocenter 9300 cd fault
    Hi
    Im no prob on BC9300 but it seems to have same problem with dead capacitors as my Beogram 7000, this is just one of the threads about that:
    http://forum.beoworld.org/forums/p/12146/90048.aspx#90048
    I cant tell you tho IF this is really your problem tho... hope any other can tell you more...
    Cheers
    Jesper
    Sweden
  • 09-15-2010 10:30 PM In reply to
    • Clive
    • Not Ranked
    • Adelaide Oz
    • Posts 22
    Clive:
    Bumping this question in the hope that someone can help.  Do the capacitor problems that seem to crop up on other 9xxx Beocenters apply to the 9300?  I have been advised that because the 9300 has the later cd mechanism fitted then the infamous cap problem doesn't apply.  Hope someone can confirm this.
  • 09-16-2010 8:40 AM In reply to
    Clive:
    That was likely me.
    It wasn't meant that the problem was NOT caps, just not the same.
    From your other thread... It may be a different cap: C2815 causing the problem(s).
    At least a place to start... anyone else?
    • B&o bottle opener
  • 09-27-2010 3:46 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    I've got one coming in for repair in about 2 weeks with exactly the same fault - so the customer says.
    I'll post back my findings on this after I have it repaired, but C2815 will be the first port of call.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 09-28-2010 8:34 PM In reply to
    • Clive
    • Not Ranked
    • Adelaide Oz
    • Posts 22
    Hi Menahem,
    I have attached a photo of the board in my 9300, Martin thought it may have been replaced at some time in the past as it was a recent type.  Be interested to know what is fitted to the one you get in.
    Regards, Clive
  • 09-28-2010 8:38 PM In reply to
    • Clive
    • Not Ranked
    • Adelaide Oz
    • Posts 22
    And the reverse side of the board.
  • 09-29-2010 1:48 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I dont know who told you that the cap problem doesn't apply.
    It certainly does, though I obviously cannot guarantee that caps are at fault in your machine.
    The SMD type caps will need replacing.
    If you don't have the tools and/or skills to replace surface mounted devices, they can usually
    be replaced by conventional through-hole components if you are handy with a soldering iron.
  • 09-29-2010 2:03 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Hi Clive,
    Thanks for the pics - that's a new one on me. The ones I've had in, in the past, have all been with regular TTH (Through-the-Hole) capacitors. I've not seen one yet with the SMD's. In general, SMD caps are far more failure-prone than regular TTH capacitors.
    IIRC, it's got something to do with the extremely high temperatures when doing "reflow soldering" during production, something which was never done in the old days....
    I learnt that through hard experience on my Tek oscilloscope - Tek used SMD's on one of the PCB's, and they leaked their corrosive electrolyte all over the fine traces - what a disaster. The other PCB's with TTH caps are still going strong.
    When replacing the SMD caps, replace them with regular TTH caps, just soldered onto the SMD bases - the machine will have a longer trouble-free lifetime.
    Menahem
  • 09-29-2010 9:04 AM In reply to
    These smd caps on the picture are definitly gone, defect. It's visible, that the top of the cap is already round and deformed, not flat any more. At least the two bigger ones have got pressure inside.
    Replace them with quite normal caps and it will work again. 90% will do it... :)
  • 09-29-2010 10:00 AM In reply to
    • kumse
    • Not Ranked
    • Joined on 11-09-2008
    • Posts 21
    Clive:
    Hello Clive
    Well.. no offence, but the guys in here are really crazy about changing caps. I had a similar problem with a B&O overture. It had a CMD12ind drive mechanism.
    I was also told to change all the caps, i tried to find some datasheets on the CMD12ind mechanism, and found out that buying all the caps with the correct specifications seemed to bee very complex.
    On the other hand i found in the service manual, that when the CD does not spin, the laser isnt able to find focus.
    I turned the overture into service mode, and could read exactly that error "focus error"
    I tried to disassemble and clean the laser unit with instructions from guides online, but with no success.
    I wanted to try to buy a new one, unfortunately the laser unit was no longer avavible (it was actually avavible when i brought the defective Overture) :)
    Nevertheless i searched ebay, and found a seller in China (gobuyjudy[AT]hotmail.com)
    , who asked me to send a picture of the laser unit. I did, and i send him ~30$. I did not really hear from him afterwards but
    14 days after, i recived what seems to be a quite good quality part. I replaced it with the broken one, and greased carefully the moving parts, and it has ben playing every day since :)
    You should know there is several different versions of the laser unit and the cd mechanism. But mine were a CMD12ind and the laser unit had the IC mounted TDA1302T
    I actually think i could have bought this one. It is similar to the one i got, and even cheaper:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270607402455&ssPageName=STRK:MEWAX:IT
  • 09-29-2010 10:14 AM In reply to
    • Dillen
    • Posts 5,008
    It's also my experience that capacitors are causing 95% (or more) of the
    faults in B&O CD players (and many other places in vintage stuff).
    The laser itself is incredibly strong and long lived.
    I say that based on 200+ repairs to B&O CD players.
    Of course a laser can fail but it is rare to see.
    After taking a look at the photo using my own PC monitor, I agree
    completely with you (the other) Martin.
    The one in the bottom left corner has definitely domed its top.
    That cap is no longer doing its job well.
    Whatever you do, DON'T adjust anything ! Setting the laser current too high will see the
    laser diode go black forever in a matter of minutes or even seconds and adjusting focus etc. without
    the proper instrumentation, test CD's etc. is asking for trouble (or a high repair bill).
    Have those caps replaced and let's see. They are definitely no good as-is.
    A note about the Ouverture:
    I've seen a couple of cases where the laser was physically blocked. It needs
    to move closer to - or away from the CD to find the focus point and to do that
    it uses a voice coil system to move the whole diode/lens system, involving
    the coil(s) and a flat metal (magnet) piece.
    In the Ouverture, it can happen that the outer surface coating (chrome or
    whatever) losens and peels off the metal piece in tiny flakes.
    There is no room for any debris in there so the coil gets stuck.
    It's a bit hard to clean out because of the magnetic forces but it can be done
    by using f.e. a corner of a post-it note (the end with the glue) and it will play again.
    I've rescued two or three with this fault by now and it could also explain
    the problem that was in Kumse's machine.
    So the capacitors in that machine are still good.
    - but as all others they won't last forever.
  • 09-30-2010 4:41 AM In reply to
    • Clive
    • Not Ranked
    • Adelaide Oz
    • Posts 22
    Thanks again guys.  You are correct in that the two large capacitors are deformed (bulging).  It was the first thing I noticed when I opened up the unit.  Replacing the capacitors shouldn't present me with too many challenges once I have sourced them but how easy is it to remove the original surface mounted items without causing any damage to the board?
  • 09-30-2010 6:39 AM In reply to
    • Dillen
    • Posts 5,008
    Note their values and polarities.
    Use pliers,  grab and twist.
  • 09-30-2010 7:23 AM In reply to
    • Clive
    • Not Ranked
    • Adelaide Oz
    • Posts 22
    Thanks Martin, now you're talking my language.  Pliers, grab, pull and twist!  I thought there may be a more 'technical' way!
    I should have mentioned that I'm a mechanical engineer so that part of the job should be simple enough for me Big Smile
  • 09-30-2010 7:48 AM In reply to
    • Dillen
    • Posts 5,008
    Don't pull !
    You will risk pulling off the copper traces too.
    Just grab and rotate.
    There is a more technical way but that involves ionized hot air soldering and since you asked the question, I took it that
    you don't have that at hand.
  • 09-30-2010 2:37 PM In reply to
    And clean the surface with a paint thinner. The defect cap has lost acid, it can corrode the copper and it can make a shortcut.
    Grab and rotate works perfect, i do it the same way, never a defect copper layer.
    Clean the solder with a unsolder copper wire, sorry, dont know the english word for this item...
    There is no need to use smd again, quite normal standard caps will work. You know the polarity of the caps? Black is minus.
  • 09-30-2010 2:50 PM In reply to
    Die_Bogener:
    Solder wick.
    • B&o bottle opener
  • 09-30-2010 2:51 PM In reply to
    Die_Bogener:
    "Solder wick" or "desoldering braid"... and the best brand is for some odd reason called "Soder-Wick" (by Chemtronics), without the L! I've tried at least three other (cheaper) brands, and none of them worked nearly as well...
    -mika
  • 09-30-2010 4:43 PM In reply to
    • Dillen
    • Posts 5,008
    Exactly my experience too. Laughing
  • 09-30-2010 5:46 PM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Soder Wick contains flux, the others don't.
    So, if you just add some flux to your regular wick, it's just as good!
    Menahem
  • 09-30-2010 8:34 PM In reply to
    Dillen:
    IF the laser is physically blocked -how is your experience with changing the laser lens? I've seen that you can buy a new laser head unit and replace it. Otherwise you can replace the whole CD mechanism. I've seen that you can replace the Philips CDM 12.1 and 12.2 with the newer VAM-1201 or VAM-1202. Any experience with that?
  • 10-01-2010 1:19 AM In reply to
    • Dillen
    • Posts 5,008
    I never had to replace a laser lens (or a laser diode for that matter) apart from one in a Beogram CD50, where the owner managed to
    scratch the lens in a desperate attempt to get the thing going (the fault was the spindle motor plus a few capacitors, as always).
    So I'm afraid, I haven't got any experience with replacing the lens and can't recommend a part.
    Regarding the blockage, if you read a bit further, you will see that a replacement of the laser was not needed. The blockage
    could be cleared and the player worked again. I've done two or three repairs of this type now so I'd imagine others would experience the same fault.
  • 10-01-2010 4:46 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Hi Kumse,
    "Well.. no offence, but the guys in here are really crazy about changing caps"
    No offense taken, but you must understand that this bunch of guys is unusual. If I may speak for all the techs here, our unusualness is that we do not subscribe to the modern lazy way of fixing things, which is to throw away the entire subassembly, PCB, or whatever, and put in a new one, at a vastly inflated cost to the consumer, but instead we do things the old-fashioned way - repairing at the component level, which is fast becoming a lost art in today's throw-away world.
    Yes, we change capacitors, because we have (may I be so bold) vast experience on these B&O machines, and capacitors were always B&O's weak points.
    In general when we replace capacitors, most of the techs here are sufficiently well-versed to replace with capacitors of much higher reliabilty than the original B&O units, therefore providing even better value and reliability to the owners.
    Simple facts, simple problems, with simple, correct and honest solutions.
    You may disagree, and that's fine. We'll continue to tackle the problems at component level, because that's the way we believe that it should be done, and which serves the owners most honestly.
    Menahem
  • 10-01-2010 5:15 AM In reply to
    100% agreement :)
