Latest post 09-09-2010 7:23 PM by njals_saga. 13 replies.
Page 1 of 1 (14 items)
  • 09-02-2010 4:06 PM
    vibrations causing records to skip
    Hi all,
    So I have my Beocentre 2200 sitting on a SC50 cabinet. I have old wooden floors in my apartment and am having trouble with vibrations from walking causing records to skip. Only taking absurdly tentative footsteps prevent this from happening.
    Is there a product or solution to stop this? I don't know, some kind of foam padding or something.
    Thoughts welcome.
  • 09-02-2010 4:23 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: vibrations causing records to skip
    Is the tracking force set correctly ?
  • 09-02-2010 4:29 PM In reply to
    Just checked and yes it is. I don't think it's a system problem. Just those darn floorboards.
  • 09-02-2010 4:36 PM In reply to
    • Dillen
    • Posts 5,008
    Well, if the whole furniture is wobbling around when you walk pass it, I am tempted to
    agree with you and in that case I hardly think we can do a lot to help you with this.
    I suppose lifting the furniture a bit off the floor and bolting it to the wall can be ruled out as a solution
    so maybe you should ask the question in a wooden floors forum somewhere ?  Laughing
  • 09-02-2010 4:43 PM In reply to
    Ha maybe.
    Well I wouldn't say the whole cabinet wobbles. It's is imperceptible to the eye. And perhaps it's wrong to say that walking causes it, rather the running and stamping around of my young child. I exaggerated with the absurdly tentative steps remark. I know it never happens when I walk by  anyway.
  • 09-02-2010 5:52 PM In reply to
    So you don't need the wooden floors forum after all ... just the "running and stamping child" forum Laughing
    One of mine once "posted" a cheese sandwich into a VHS recorder's mouth and pushed it right to the back of its throat Laughing Laughing Laughing
    Welcome to a new and terrifying reality
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 09-03-2010 12:21 AM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Just do a search on eBay for "turntable isolation feet" and you'll find products such as this.   A better solution might be to place a folded towel under the Beocenter but this might well interfere with air circulation and cause overheating.
  • 09-03-2010 6:50 AM In reply to
    Or put a thick square single piece of wood under the stand to help take the vibrations away from the floor
    Train Hard - Run Fast - Hit to Kill!!!
  • 09-03-2010 10:40 AM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    I am not making this up.
    Yesterday I was goofing off on The IntarWebs and came across a DIY isoloation project.
    Picture the bottom half of a shallow wooden box, just larger than your turntable.
    Got that picture in your head?  Now put an inflated bicycle tire inner tube (the kind for 20" BMX bikes) inside the box.  The inner tube isn't fully inflated - probably to 90% capacity.  The inner tube is sticking out of the shallow wooden box 1/2" to 1".
    OK, now take a big ol' piece a wood, like a giant butcher block, and set that down centered over the inner tube and box.
    Now place your turntable on the butcher block.
    The creator of this DIY project said he did it all for less than $20 plus glue, stain and varnish he already had on hand.
    If anyone really wants me to, I'll try to track down the site again.  (I'm goofing off on The IntarWebs again today Stick out tongue)
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 09-03-2010 1:49 PM In reply to
    Silly question. Are the transit screws fully undone? I have had wooden floors and never had that problem.
  • 09-03-2010 4:00 PM In reply to
    Peter :
    or take a look at the picture Peter posted here Laughing
    http://forum.beoworld.org/forums/t/35259.aspx
    Look at the shelf mount, and the feet supporting the beogram
  • 09-09-2010 11:44 AM In reply to
    Clamp the SC50 to the wall
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 09-09-2010 3:03 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Peter :
    Exactly what I thought as I read through this thread. Records shouldn't skip just by walking past due to the internal supension.
    The 3 transport screws are located under the platter which should be "springy" when they are released.
    Chris.
    EDIT - just read the bit about running children. If the transprt screws are released then another good way of isolating your deck is 4 hard compound squash balls in cups/rings - one under each corner.
  • 09-09-2010 7:23 PM In reply to
    @elephant
    @medogsfat
    So it was indeed the transit screws that were the culprit. Full a bit silly now blaming the wooden floors. Problem solved. Thanks a million.
    Thank god I tried your suggestion before I started messing about with squash balls.
