Latest post 08-30-2010 9:26 PM by SWISS_2. 2 replies.
Page 1 of 1 (3 items)
  • 08-30-2010 1:28 PM
    Sketches BV 10 & BL 8000 & BL 11 Wall mounting
    I would need the sketches for wall mounting the BV 10-46, BL 8000 & BL 11 so that I know where to make the cable outlets from the wall so that you won't see any cables when it's finished and should then look like this: Smile
    BV10BL8000
  • 08-30-2010 1:34 PM In reply to
    Re: Sketches BV 10 & BL 8000 & BL 11 Wall mounting
    And the BL 11 should then look like this: Smile
    BL11
  • 08-30-2010 9:26 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Lifestyle:
    You provide a nice, minimalist, well-organized photo concept.
    There are sample illustrations in the BV-10 operation manual, available to Beoworld Gold members.  However, without more specifics, a few questions arise:
    1. What is your actual wall construction ?
    2. Distance between speakers and BV-10 ?   Same with the subwoofer ?
    3. Distance to mains/electrical supply ?
    4. Distance to additional  B&O or other stereo system,  cable, SAT TV, or  HTPC components ?  Are you also planning to M-L link the system into other rooms ?
    If helpful, I ran a horizontal conduit under the BV-10 to the BL 4000 active speakers we use. This is silicone conduit which facilitates easy cable pulling and no snags. Our location is masonry, not easy but at least to code.
