Ok I will get one this week. Microcenter probably sells them otherwise I will get one off eBay. (the antistatt mat)
Bought this unit for $99 dollars including shipping. came with a remote which was about the only way to test it. The front keypad was loose and several of the button had slipped out. It was rather hit or miss.
The tape of course did not work (belts) what is left is a gooey mess, plus the casssette holder woul not close completely (broken piece, not sure of its function, tray alignment maybe) but I seperglued it back in place.
The manual tuning dial was stuck at the top of the FM dial. A little lube fiddling and adjusting the loose scew on the tuning wheel has it more or less working again. ( probaly need a little more lube and fiddling.
Dont remember if the lights worked or not the unit played nice and the best part of the deal had to have been the MC20EN stykus, under magnification it loks practically brand new and plays like it too.
From what I can see I unplug the cassette wiring, remove three screws on top and the the whole mechanism will pull out. Not that restoring the   cassette is really that big of a deal to me but since I have the unit apart why not. Just need a belt(s).
Found an anti stat bag and put the CP inside
