lano:
Hi, how can you tell if a Beovision 3-32 has anti-reflex coating or not?
The coating is on the outer face of the screen/ glass front and has a bluish tinge to it visible when the TV is switched off. The Avant and BV5 have fine slightly irregular horizontal lines in the coating visible with strong side lightling and/or under magnification. The coatings are easily damaged and close inspection of small marks on the screen will probably confirm the presence of the coating. I don't have a BV3 but would guess its coating will be like the Avant.
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
