Latest post 08-24-2010 4:35 AM by Dude1. 2 replies.
Page 1 of 1 (3 items)
  • 08-23-2010 4:43 PM
    • lano
    • Not Ranked
    • Joined on 04-25-2010
    • Posts 66
    • Gold Member
    Anti-reflex coating
    Hi, how can you tell if a Beovision 3-32 has anti-reflex coating or not?
  • 08-23-2010 5:28 PM In reply to
    Re: Anti-reflex coating
    lano:
    The coating is on the outer face of the screen/ glass front and has a bluish  tinge to it visible when the TV is switched off. The Avant and BV5 have fine slightly irregular horizontal lines in the coating visible with strong side lightling and/or under magnification. The coatings are easily damaged and close inspection of small marks on the screen will probably confirm the presence of the coating. I don't have a BV3 but would guess its coating will be like the Avant.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 08-24-2010 4:35 AM In reply to
    • Dude1
    • Top 500 Contributor
    • Joined on 09-18-2007
    • London
    • Posts 189
    Some do, some don't. A blueish tint to the front of the screen means you do.
