Hello everybody. Recently I've noticed that the Centre bearing has backlash. I tried to fix it by myself but if ended tragically.Now I need to replace it , if it is possible. I'm not sure if that part is replaceable nor do I need whole chassis. Has anyone of you got this part or any other advice? I attached a photo of this part so you can see clearlly what I've done and what I need.
In my humble opinion, the centre bearing is not easily replaceable as it is pressed into the chassis.
Much easier to just change the chassis.
Regards Graham
I thought so. does anybody have the chassis? or whole beogram for spares?
