Latest post 08-22-2010 5:26 PM by niceman. 2 replies.
Page 1 of 1 (3 items)
  • 08-19-2010 7:00 AM
    Beogram 8500- centre bearing
    Hello everybody. Recently I've noticed that the Centre bearing has backlash. I tried to fix it by myself but if ended tragically.Now I need to replace it , if it is  possible. I'm not sure if that part is replaceable nor do I need whole chassis.  Has anyone of you got this part or any other advice? I attached a photo of this part so you can see clearlly what I've done and what I need.
  • 08-19-2010 8:34 AM In reply to
    Re: Beogram 8500- centre bearing
    In my humble opinion, the centre bearing is not easily replaceable as it is pressed into the chassis.
    Much easier to just change the chassis.
    Regards Graham
  • 08-22-2010 5:26 PM In reply to
    I thought so. does anybody have the chassis? or whole beogram for spares?
