Latest post 06-27-2007 8:39 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 06-27-2007 7:32 AM
    Spares - CD insert for Beocenter 9000
    Hi all - I have a Beocenter 9000 and a small black disc surrounded by a spring which holds the cd in place has cracked, no longer holding a cd.  Been to 2 B&O shops, both who said you would need to replace the cd unit using a CD REPAIR KIT - no one seems to stock one of these (emailed all 200+ dealers...).  Any one have any ideas?  Seems crazy to write off a whole system for such a tiny (but significant) fault!
    John
    Filed under:
  • 06-27-2007 8:39 AM In reply to
    Re: Spares - CD insert for Beocenter 9000
    The cap and spring is no longer available and there is no CD repair kit to my knowledge. B&O are aware of the problem and you can get a magnetic cd clamp pt number 3152703 to replace the spring.
    The original cap and spring was part number 3164690 and you may be lucky to find a service dept with one still in stock. Bit of a long shot though.
    Regards Graham
