Latest post 06-27-2007 5:06 PM by Jandyt. 15 replies.
Page 1 of 1 (16 items)
  • 06-27-2007 6:06 AM
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Com 6000 PIN CODE
    Just bought a 2nd hand 6000. Can't get hold of the PIN code at moment. Anyone know a short cut to get it started?
            Jonnie
  • 06-27-2007 6:30 AM In reply to
    Re: Com 6000 PIN CODE
    The BeoCom 6000 does not have a PIN code, you get that prompt if the PSTN base has maximum handsets registered (I'm guessing this is not the case) or the handset is registered to several bases.  Reset the handset by pressing 'dot' 70009.  If it still does not register, de-register all your handsets, reset them and re-register them 1 by 1.  Do not reset your base because you will lose all your phonebook entries,
  • 06-27-2007 6:41 AM In reply to
    The BeoCom base has a 4 digit pin code, the default which most people don't change is 0000
    Regards Keith....
  • 06-27-2007 8:43 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    I have reset handset. When i try and register a base it accepts the base but then asks for a pin code??????????
  • 06-27-2007 8:45 AM In reply to
    Put in the default pin code of 0000
    Regards Keith....
  • 06-27-2007 8:46 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Yep tried that Keith. Just says not registered.
       jonnie
  • 06-27-2007 9:17 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    De-registered all phones. Registered 1 by 1 and after a few goes with dodgey phone finally got the monkey working.
         Thanks for your help guys.
         Jonnie
  • 06-27-2007 9:25 AM In reply to
    Well done Jonnie.
  • 06-27-2007 2:06 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    While we're on the subject, I just bought 6 handsets and pyramid chargers (For £427!) and when they arrived, I was shocked to find they are the new type with headset sockets.
    Unfortunately the manual was for the old type. I downloaded one of Peter's manuals but it doesn't say what the equivalent of dot 70001 is. To get to the s/w version.
    Anybody know, Keith?
    Andy T.
    Poor me, never win owt!
  • 06-27-2007 2:14 PM In reply to
    • Ian
    • Top 500 Contributor
    • UK
    • Posts 132
    9#9#9*INT
     Ian
  • 06-27-2007 2:27 PM In reply to
    • Jandyt
    • Posts 13,004
    Cheers Ian. Quite an extensive menu in there, isn't it, compared with MK1
  • 06-27-2007 3:48 PM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    jandyt:
    Andy T.
    How good a bargain did you get Andy. Those ten seconds are haunting me Angry
  • 06-27-2007 4:25 PM In reply to
    • Jandyt
    • Posts 13,004
    Never mind, Jonnie. There's always next time.
    Meanwhile, here is some salt for your woundWink
  • 06-27-2007 4:45 PM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    jandyt:
    Thankyou!!!! A glass of that stuff on the worktop now called for.
        Jonnie
    • JC
    • Yorkshire / UK
    • Posts 621
    jandyt:
        Jonnie
  • 06-27-2007 5:06 PM In reply to
    • Jandyt
    • Posts 13,004
    It's "Soberano", Spanish brandy. I have a tot of that every night in my coffee before bed.
    Andy T.
