Latest post 12-02-2011 6:35 PM by MB. 12 replies.
Page 1 of 1 (13 items)
  • 08-11-2010 7:15 PM
    beovox ht 1500 speakers
    Hi Has anyone any info on these speakers, i know there is info on here regarding them but i don't think any of it is correct. I would also like to know what the general opinion of them was at the time of manufacture. Thanks
  • 08-12-2010 2:55 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beovox ht 1500 speakers
    Welcome to Beoworld !
    What info are you looking for and why do you think that none of the info given in the product guide is correct ?
    The Beovox 1500 is a rare speaker.
    It has a pleasant sound for it's age, most likely because it has a considerable size for a 15W speaker.
    Not a party-speaker but it will sound fine with a Beomaster 900 or similar.
  • 08-12-2010 7:41 PM In reply to
    Hi Martin I have a pair of these speakers which i found dumped at the local recycling center, i've been using them with an old valve amp wired through our digital tv and think they sound wonderful. The dimensions, weight and power handling are nothing like whats stated on here, so suspect the frequency response mentioned is also probably not correct and would like to know what this is. i also found a pair of B and O 2702's  and swapped the seas tweeters to the 1500's. John
  • 08-13-2010 7:28 AM In reply to
    • Dillen
    • Posts 5,008
    Oh yes, the dimensions are definitely wrong, too small.
    Maybe you can give us the correct dimensions ?
    And maybe a brief description for us to include in the produt guide ?
    That would be nice.  Big Smile
  • 08-13-2010 3:32 PM In reply to
    • Dillen
    • Posts 5,008
    OK, here are the correct specs for Beovox 1500 (Type 6209):
    Size: 635 (width) x 280 (height) x 305 (depth), volume 38 Liters.
    Three-way with crossover frequencies at 800Hz and 5KHz.
    Woofer : Seas 28/17 TV-GW
    Midrange : Peerless G 50 MRC
    Tweeter : Peerless MT 25 HFC
    Frequency range 45-18000Hz (DIN 45570).
    Power rating 15W (25W max).
    Impedance 4 Ohms.
    Available in Teak and Palisander.
    Has a midrange adjustment (rotating switch with 5 settings) at the back.
    An owners review would still be nice.  Whistle
  • 08-15-2010 3:54 AM In reply to
    Done - are the pictures correct?
  • 08-15-2010 6:20 AM In reply to
    • Dillen
    • Posts 5,008
    Thanks, Peter.
    The photos are OK.
    Maybe we should add that a 2-pin DIN socket is also provided for an external tweeter.
  • 08-15-2010 7:14 AM In reply to
    Done , and added the above picture!
  • 08-20-2010 6:39 PM In reply to
    Hi Thanks Martin and Peter for the info, regarding the Beovox 1500 speakers.
  • 08-30-2010 2:38 AM In reply to
    Thanks to sajpratty, we now have an excellent review of these speakers on site. More reviews like this are always welcome. I can edit and add links to any content I am sent.
  • 08-30-2010 3:18 AM In reply to
    • Dillen
    • Posts 5,008
    Great !
    Yes, they are wonderful vintage speakers.
  • 08-30-2010 7:13 AM In reply to
    It was a real pleasure to give them a listening; I gave them as much help as I could by matching the components and records.
    Cheers, Steve
  • 12-02-2011 6:35 PM In reply to
    • MB
    • Not Ranked
    • Joined on 12-02-2011
    • Posts 1
    My experience with the Beovox HT 1500 (Type 6209)
    To be honest I bought those speakers for their name. B&O. Sounds great, dosn't it? Gave them a short listening and decided I would sell them again. Not that I realized any faults, it was just there was no „shock and awe“-feeling if you get what I mean. They simply seemed to be ordinary.
    For sale I did a short research and hit on the review for the HT 1500 (or Type 6209) on this site. The review being very positive about these speakers I decided to give them another listening.
    And it was good that I did, because otherwise I would lack a wonderful impressive speaker today. These old speakers are incredibly good. Yes, incredible good. The more I listen to them (by comparing them to other speakers) the more I am impressed.
    I don't own any current B&O, but I do own some MB Quart, Canton, Boston Acoustics, ACR and some more. And wow these Babys pull it off:
    The HT 1500 have a decent bass output, you notice it, it is powerful, it is crisp and best of all – its not overpowering and it fits nicely with the rest of the Mids and Highs.
    These speakers sound clear, lofty, wide open, with a lot of rich, natural detail. I simply love them.
    If you have the opportunity to buy a pair in working order, why not give them a try? They are worth it. They are probably not the best money can buy, but they are among the best you can buy for little money.
    And don't ask me why you can plug in an external tweeter, the built-in tweeter is wonderful as it is!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
