Latest post 10-13-2010 3:18 PM by Alias. 15 replies.
Page 1 of 1 (16 items)
  • 08-08-2010 7:37 AM
    Beoport IR eye controlled with Beo4
    Hi dear members,
    Have a Beoport which I want to control with my Beo4 remote. What IR eye (puck) type do I need since I think there are several types?
    Thanks! Leslie
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 08-08-2010 7:59 AM In reply to
    Re: Beoport IR eye controlled with Beo4
    Leslie:
    The BeoPort puck has no inscriptions; the BeoLink Active/Wireless puck has the words "PLAY", "TIMER" and the symbols "v" and "^" on it.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 08-08-2010 9:51 AM In reply to
    Thanks Elephant! So one type only and that type I can use?
  • 08-08-2010 1:25 PM In reply to
    Well there are at least two types of pucks.
    But only the one with the blank face is the BeoPort's.
    I am not sure of their part numbers ... sorry.
    I have checked my PDFs including the Service Manual but there are no clues there.
    Perhaps the PRODUCT section of Beoworld or Beotech might have them.
  • 08-08-2010 1:39 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    hi there
    i got a spare unit here currently minus lead but i have one of those too a simple task to resolder the lead back in place - if interested pm me etc
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 08-08-2010 1:45 PM In reply to
    Tony, check PM!
    Leslie
  • 09-09-2010 4:25 PM In reply to
    Is this (found on Ebay UK) something I could use for controlling my Beoport (Beo4)
  • 09-10-2010 4:35 AM In reply to
    Hard to tell from the fuzzy photo, but it looks like the "eye" does not have writing nor a light ... so it could very well be the addition you are looking for !
  • 09-10-2010 5:43 AM In reply to
    Thanks "mate"!Yes -  thumbs up
    Leslie
  • 09-10-2010 6:22 AM In reply to
    • Teletom
    • Top 500 Contributor
    • Joined on 05-09-2007
    • the Netherlands
    • Posts 111
    • Gold Member
    Leslie:
    Difficult to see on that picture. As you know there are two different link-eye models.
    The correct one for BeoPort has partnumber 8087030 and has 2 unlabled buttons. The standard IR eye has 4 labled buttons (timer, up, down and play)
  • 09-10-2010 2:37 PM In reply to
    Dank je Teletom voor de xtra informatie...Smile
  • 09-10-2010 4:25 PM In reply to
    It doesn't make any difference which one you want to use.
    Both types are suitable. The main function for the ir-eye is to receive the ir-instructions from the remote and send the data through the lead to the beoport.
    The one with the buttons can be used, but only the buttons itself will not work.
  • 09-10-2010 4:36 PM In reply to
    BetterSmile
    Thank you AV (Beobuddy). Anybody who can offer me one for a fair price if Ebay fails? Must be in scratchles condition... Also looking for a mint condition BL7000 touchpanelWhistle
  • 10-13-2010 2:58 PM In reply to
    • Alias
    • Joined on 04-23-2008
    • Posts 90
    I know it is an old thread but I don't want to start a new one.
    How is the wiring for the IR eye? They are some colors but I don't know where to connect.
    Thank you
  • 10-13-2010 3:13 PM In reply to
    Maybe this thread could help?
  • 10-13-2010 3:18 PM In reply to
    • Alias
    • Posts 90
    Thanks Leslie!
