1st March February 2012
Latest post 10-13-2010 3:18 PM by Alias. 15 replies.
08-08-2010 7:37 AM
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Beoport IR eye controlled with Beo4
Hi dear members,
Have a Beoport which I want to control with my Beo4 remote. What IR eye (puck) type do I need since I think there are several types?
Thanks! Leslie
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
elephant
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 2,215
Re: Beoport IR eye controlled with Beo4
Leslie:What IR eye (puck) type do I need since I think there are several types?
The BeoPort puck has no inscriptions; the BeoLink Active/Wireless puck has the words "PLAY", "TIMER" and the symbols "v" and "^" on it.
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
Leslie
- Netherlands
- Posts 2,201
Thanks Elephant! So one type only and that type I can use?
elephant
- Posts 2,215
Well there are at least two types of pucks.
But only the one with the blank face is the BeoPort's.
I am not sure of their part numbers ... sorry.
I have checked my PDFs including the Service Manual but there are no clues there.
Perhaps the PRODUCT section of Beoworld or Beotech might have them.
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
hi there
i got a spare unit here currently minus lead but i have one of those too a simple task to resolder the lead back in place - if interested pm me etc
tony s
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Leslie
- Netherlands
- Posts 2,201
Is this (found on Ebay UK) something I could use for controlling my Beoport (Beo4)
elephant
- Posts 2,215
Hard to tell from the fuzzy photo, but it looks like the "eye" does not have writing nor a light ... so it could very well be the addition you are looking for !
Leslie
- Netherlands
- Posts 2,201
Thanks "mate"!
Leslie
Teletom
- Joined on 05-09-2007
- the Netherlands
- Posts 111
Leslie:
Difficult to see on that picture. As you know there are two different link-eye models.
The correct one for BeoPort has partnumber 8087030 and has 2 unlabled buttons. The standard IR eye has 4 labled buttons (timer, up, down and play)
Leslie
- Netherlands
- Posts 2,201
Dank je Teletom voor de xtra informatie...
Beobuddy
- Joined on 04-18-2007
- Posts 1,582
It doesn't make any difference which one you want to use.
Both types are suitable. The main function for the ir-eye is to receive the ir-instructions from the remote and send the data through the lead to the beoport.
The one with the buttons can be used, but only the buttons itself will not work.
Leslie
- Netherlands
- Posts 2,201
Better
Thank you AV (Beobuddy). Anybody who can offer me one for a fair price if Ebay fails? Must be in scratchles condition... Also looking for a mint condition BL7000 touchpanel
Alias
- Joined on 04-23-2008
- Posts 90
I know it is an old thread but I don't want to start a new one.
How is the wiring for the IR eye? They are some colors but I don't know where to connect.
Thank you
Leslie
- Netherlands
- Posts 2,201
Maybe this thread could help?
Page 1 of 1 (16 items)
