Gary,
Thank you for your kind feedback
I do not sell, licence or distribute my software and it is ONLY on my system. I developed the software about a year after the introduction of the Beo5 to create working "Drag-n-Drop" 3rd party XML files which have the digits and hard keys pre-assigned because even today the B&O Beo5 Configuration Tool falls well short of requirements when it comes to third party products.
The software can use Lintronic timing output, any Pronto HEX codes, convert from any PUC entry, from directly entered RC5 or NEC codes and directly capture from an original remote in real time using an IR receiver connected to a USB port.
The Beoworld 3rd Party XML Generator is more limited and can only convert Lintronic timings to RAW or RC5 codes from manually entered data. It does not pre-assign any hard keys and as it only uses RAW which is an image copy of the original means it cannot handle repeat function used by many remotes. So, to use the XML Generator other than for manually entered RC5 codes requires you to purchase a Lintronic box and you can find more details HERE
The problem for many members is if they just want to capture one or two remotes the purchase of the Lintronic box is an expensive option unless it will be used for controlling something else subsequently.
