Latest post 08-25-2010 11:22 AM by StUrrock. 17 replies.
Page 1 of 1 (18 items)
  • 08-02-2010 4:42 PM
    HDMI Matrix
    Has anybody got some details on the proposed HDMI matrix solution that I have heard about.
    I would think it would use a gefen unit as this used for the HDMI switcher -is it only compatible with certain TV's or will there be a software update to enable all the latest tv's to take advantage.
    Simon
  • 08-02-2010 5:20 PM In reply to
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    Re: HDMI Matrix
    Ours arives tomorrow will let you know how we get on!
  • 08-02-2010 5:23 PM In reply to
    Re: HDMI Matrix
    Please do tell
  • 08-03-2010 1:59 PM In reply to
    Re: HDMI Matrix
    Hi Sturrock,
    Any news, specs etc Erm
  • 08-05-2010 6:30 AM In reply to
    Re: HDMI Matrix
    *bump*
     *bump*
     *bump*
     *bump*
     *bump*
     *bump*
     *bump*
     *bump*
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 08-08-2010 5:07 AM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Re: HDMI Matrix
    Hello?
    Any feedback on the system?
    I'm building the plan of my future house and would like to know what is needed, espcially in terms of wiring.
    Have a great sunday!
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 08-08-2010 5:29 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: HDMI Matrix
    YannChris:
    ... would like to know what is needed, espcially in terms of wiring
    Each "Central HD-Source" e.g. Video-Server, SAT-Receiver, ....
    requires a pair of CAT7 Cables from each "Client TV" to "Central Tech-Area"
    For example: 3 "Central Sources"  >> 6 CAT7 to TV "Livingroom" ;  6 CAT7 to TV "Bedroom" ; 6 CAT7 to ...
  • 08-08-2010 5:55 PM In reply to
    Re: HDMI Matrix
    I know it would cat 5,6 or 7 cables etc as this is what the \HDMI baluns currently use,
    there is a HDMI over IP solution available but it's early days yet with this tech & we know that B&o move at a snails pace.Surprise
    I am more interested in the general specs i.e. what are the supported models, will they all require a update to enable, what about digital audio will this be in addition to ML audio i.e. could a Apple TV/mac mini  be used for full resolution audio distribution to say another system while the ML is being currently used.
    I think it will use a Gefen HDMI matrix that will connect to the video master, but will they go the whole hog and enable a a master to control a slave  so i.e. a true matrix.
    Only time will tell unless others spill the beans first.Wink
  • 08-09-2010 7:54 AM In reply to
    • StUrrock
    • Cambridgeshire
    • Posts 219
    Re: HDMI Matrix
    The Matrix is here, just awaiting the activation codes from Struer then will let you know.
  • 08-13-2010 1:46 PM In reply to
    • tompa
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    Re: HDMI Matrix
    No thats not right !  not so many CAT7
    Matrix "brand" is not gefen it's ATLONA
    Ex 1.
    If you have the matrix ( ATLONA) in let's say livingroom were videomaster and sources is
    you need hdmi conection from each source to matrix and then 2 Cat 6/7 to each linkroom from matrix, depending on matrix model
    you can have 3 or 7 linkroom (1 output connected to videomaster (HDMI)) and 4 or 8 sources and Puc cable to videomaster
    Ex 2.
    If you have technical room were the source and matrix placed you have HDMI between sources and matrix and CAT 7 X2 to each
    linkroom and videomaster and also Puc cable from videomaster to matrix
    In all linkroom you need CAT7 converter to HDMI (in Ex 2. also to videomaster if to long for HDMI)
    /Tompa
  • 08-13-2010 3:59 PM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    Re: HDMI Matrix
    Interesting. Thanks for the hint. I never heard of Atlona before. So I guess you need two CAT5 and Masterlink (CAT7?) to every link room.
    Makes sense.Do you know more about the HDMI matrix? Price? Which Beovisions aresupported?
    I`m thinking of this product: http://www.atlona.com/Atlona-4x4-HDMI-Matrix-Switcher-over-Cat5-Cat6.html
    Stefan
  • 08-13-2010 5:54 PM In reply to
    • Vienna
    • Posts 712
    Re: HDMI Matrix
    stefan:
    Price?
    Stefan
    8x8 ~ 5-6 k EUR
    TVs with menue - activate function - "HDMI Matrix" - like BV 10-40/46, BV 7-40/55, ...
    for larger setups / distances up to ~ 50m rather this one ...
    http://www.atlona.com/Atlona-8x8-2-PRO-HDMI-Matrix-Switch-with-CAT5-6-and-Local-HDMI-Outputs-with-3D-Support.html
  • 08-15-2010 9:28 AM In reply to
    • tompa
    • Sweden
    • Posts 94
    Re: HDMI Matrix
    Yes you need 2 cat5/7 for HDMI and 1 Cat 7 for ML
    Beovision supported are at this moment beosystem 3 based (BV7-40MKIII and later,BV4 with Bsys3,BV9) bv8,Bv10
    Software uppdate maybe needed
    the models of Atlona that are in Puc support now is AT-ProHD44,48,88 maybe other model work depend on ir commands
    price depends on country, but you get a hint in at atlona.com 2500eur on the model you have looked at.
    /Tompa
  • 08-24-2010 12:03 PM In reply to
    • StUrrock
    • Cambridgeshire
    • Posts 219
    Re: HDMI Matrix
    Well we have had the 8x8 matrix for a couple of days now and wow it works beautifully with our feature activated BVIS 10 46 and 40s.
    To work it smoothly you will need a Beo5 and to activate your TV to work the Matrix you will have to pay a license to B&O.
    Having worked with other HDMI matrix solutions, this is the smoothest and most easily configured oiption out there!
    Well done Struer we are onto a sure fire winner here!
  • 08-24-2010 12:54 PM In reply to
    Re: HDMI Matrix
    StUrrock:
    Is this is a one off fee?  Is it per TV?  How much do they charge?
  • 08-25-2010 5:52 AM In reply to
    • StUrrock
    • Cambridgeshire
    • Posts 219
    Re: HDMI Matrix
    The fee is per TV each shop will vary in price, I suppose depending on the particulars of the sale/installation.
  • 08-25-2010 7:34 AM In reply to
    Re: HDMI Matrix
    Any vague indication? Are we talking £10? £100? £1,000?
  • 08-25-2010 11:22 AM In reply to
    • StUrrock
    • Cambridgeshire
    • Posts 219
    Re: HDMI Matrix
    csmager:
    between £350-500
