Latest post 07-25-2010 9:10 AM by Vienna. 3 replies.
Page 1 of 1 (4 items)
  • 07-25-2010 5:07 AM
    • rpaul
    • Not Ranked
    • Joined on 05-16-2007
    • Wiesbaden
    • Posts 10
    • Gold Member
    BV7-40 Motorized Stand Failure
    After a few years running without any problems the motorized stand moved far right without any apparent reason. Switching TV on-off-on does not have any effect. After switching on, the stand moves to the position as programmed for video mode but immediately after reaching this position, it turnes itself again far right. Anybody experienced such a failure? It is a BV7-40 mark II, STB attached via Scart.
    Regards, Reinhard
    Reinhard
  • 07-25-2010 6:09 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: BV7-40 Motorized Stand Failure
    rpaul:
    Switching TV on-off-on does not have any effect. After switching on, the stand moves to the position ...
    As a first step try the following procedure - sometimes it resolves the problem:
    - unplug the cable to the stand
    - disconnect (unplug !) power of your TV
    - wait 1-2 min and reconnect to the mains - w/o stand beeing connected
      making the TV "believe" there is no stand connected and erasing it's memory
    - turn on TV for 1 minute
    - wait 1-2 min and reconnect to the cable to the stand
    - restore power
    - wait 1 min before switching on
    - wait 1 min before before you run through the setup for positions of audio, video & standby
    - now you should be able to store these positions again...
    If this does not help I'd call B&O service for a homeservice ...
  • 07-25-2010 8:07 AM In reply to
    • rpaul
    • Not Ranked
    • Wiesbaden
    • Posts 10
    • Gold Member
    Great, it worked after 2 tries. First time I just did not wait long enough after unplugging the stand and the TV.
    Thanks a lot for ypur fast reponse and assistance!
    Reinhard
    Reinhard
  • 07-25-2010 9:10 AM In reply to
    • Vienna
    • Posts 712
    My pleasure!
    PS: Smile ... jaja, unsere ungeduldigen Lieblingsnachbarn ... *g*
